Air intake question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-01-2005, 01:45 AM   #1 (permalink)
Take me to the candy shop
View '95 Avalon XLS's Photo Gallery
Question Air intake question
sorry for intruding the camry forum =P, oh well... we're all toyota people. anyways, i have a question about installing the air intake. i want to replace my stock filter with the intake kits on ebay. just wondering where does that small box connect to the pipe. on the pipe there's a retangle space for you to connect something on and that part got me confused. lol sorry if i'm getting you confused too. need some clear directions plz, i'm slow
'95 Avalon XLS is offline   Reply With Quote
Old 03-01-2005, 03:23 AM   #2 (permalink)
Working hard?
View noofa's Photo Gallery
step 1 remove the panel filter inside the airbox
Step2 remove the - around 5 - bolts from the bottom half of the box.
step 3 remove the bottom half of the airbox and if you smoke use it as an ashtray
step 4. remove the again around 5 screw/bolts (keep them) from the top half of the box, the top half should now come loose and can be removed
step 5 you can now use the 4 bolts to attach the new air intake usinf the same screw/bolts
the Air intake should now be fine.
Hope this helps
u proberbly could have done a search!
Rep'in Team Hamster In OZ
Need power? Get an Ebay Intake mod!!!
***MOD: Signature violation. Size is too big. Keep it under 500x150 pixels.***
noofa is offline   Reply With Quote
Old 03-01-2005, 04:56 AM   #3 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Its for the MAF (mass air flow) sensor.
What you do is unscrew the part from your stock MAF and mount it onto your new intake pipe.
"Skoolin' the unlearned!"
