3sgte swap. Questions Before i start to buy stuff - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-01-2005, 04:55 AM   #1 (permalink)
Working hard?
View noofa's Photo Gallery
2nd Generation 3sgte swap. Questions Before i start to buy stuff
Im about to buy all the gear i need for the 3sgte conversion (it will be slow) but before i potentialy start wasteing my money i want to confirm a few things with you guys
1 the engine slots straight in on the 3sfe mounts.
2 the engine will bolt up to the tranny and exhaust (before or after cat?)
3 the auto tranny i have will not last long? How long is not long if i baby the thing till i can afford it?
4 the Gen 2 GTE is slightly lower in HP but there is more aftermarket gear avaliable?
5 brake upgrade required?
6 Intercooler? whats the go there?
Anyway i have searched this subject heaps and just want to be sure before i fork out a heap of dollars. Thanks for any reply.
Rep'in Team Hamster In OZ
Need power? Get an Ebay Intake mod!!!
***MOD: Signature violation. Size is too big. Keep it under 500x150 pixels.***
noofa is offline   Reply With Quote
Old 03-01-2005, 05:31 AM   #2 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Yes, or IIRC you can use the mounts from a Celica All Trac/GT4.
I asked Wraith about it along time ago and IIRC he said you can also use the mounts from a Celica.
Yes on the tranny.
The exhaust will most likely have to be custom. I suggest upgrading the entire exhaust system anyways. Goto 2.5" - 3" pipe. The aftermarket turbo kits I've seen for 3S-GTEs have phatty 3" downpipes.
3S-GTEs were never mated with a auto tranny. The exception is the Caldina (ST215), it has a 3S-GTE mated to a auto tranny.
So unless you get ahold of a Caldina clip or use a full standalone computer, forget about using a auto tranny with a 3S-GTE.
IIRC 1st and 2nd gen 3S-GTE is rated at 225hp. 3rd gen is rated at 245hp. This is for JDM 3S-GTEs.
The difference is with the ports, runners, and turbo. Something like that. Wraith would know more about it.
Theres tons of aftermarket parts for a 3S-GTE. I don't think most parts are generation specific, a 3S-GTE is a 3S-GTE.
Not required, but probably a good idea.
You can use the front brakes from a Celica All Trac/GT4. And for the rear you can use the brakes from a gen 2 V6 Camry (they came with rear disc brakes).
http://www.geocities.com/ignatius_tse/brakes
Celica All Trac/GT4 use a top mount intercooler (tmic). Some generations were air cooled and some have a air to water intercooler.
I would use a front mount intercooler (fmic).
"Skoolin' the unlearned!"
Old 03-01-2005, 02:37 PM   #3 (permalink)
View TypeRex187's Photo Gallery
Did the US spec Celica come in 3s-gte? I don't remember if they did or not, but if they do can you use the parts from that instead of a GT4?
2006 Camry SE, Vizage Kit 2004+, TRD RSB, Ksport Coilovers, FOR SALE: Gold Gewalt 19x8 +38 5x114, BridgeStone RE050a 245/45/19 65% tread lefted, Volk Evolution I 16x7 +38 5x100, Vizage 5.5 Front Lip, C-West Bumper 99' Civic, PM ME!
TypeRex187 is offline   Reply With Quote
Old 03-01-2005, 03:46 PM   #4 (permalink)
Zzzz
CrawlingEye's Avatar
View CrawlingEye's Photo Gallery
...yeah?
gt-4 and all-trac are the same cars.
-mark
'93 Camry LE (5S-FE)
CrawlingEye is offline   Reply With Quote
Old 03-01-2005, 07:28 PM   #5 (permalink)
Working hard?
which manual tranny can i use with the 3sfe and the 3sgte- i want to get the tranny installed first???
Old 03-01-2005, 07:36 PM   #6 (permalink)
Toysrme's Avatar
View Toysrme's Photo Gallery
Cool
E153.
Three versions. The Celica/all-track one, the early year camry v6 ones (through '93) and the later ones. Get a 93+. They changed the synchros in 93 for better operation.
They all will bolt up. Which one does he need for eveything to line up? The v6 ones, or the celica one?
AIM/Yahoo Toysrme257th
Now with Turbo!
Old 03-01-2005, 07:42 PM   #7 (permalink)
Working hard?
im aiming for around 450 hp btw
Old 03-01-2005, 07:58 PM   #8 (permalink)
Zzzz
no offense, but I hope you have an assload of money to spend and don't plan on keeping it streetable.
the 3sgte + tranny will be quite a bit of money in itself, then you'll need a standalone or to have everything rewired in the least (EMS would better suite you for performance), plus a larger turbo (ct-26 will NOT get you there)... The list goes on...
Don't mean to down yah, if you get this project rolling, more power to yah, but it's going to be QUITE an expensive project.
-mark
Old 03-01-2005, 08:04 PM   #9 (permalink)
Working hard?
yeh i understand that it will be expensive, but im doing it over time so i will begin with the engine tranny and exhaust. These will cost around (aud) 2000 engine 1000 tranny and 400 for the pipe plus install for the engine,and tranny so i figure i can have done stage one for 5000 to 6000. what do you guys think?
Old 03-01-2005, 08:05 PM   #10 (permalink)
Zzzz
sounds fine to me, but unless you intend on having the ct-26 modded, you may as well go for a different turbo. No sense in buying something you'll need to replace later on anyhow (just costs you more in the long run)
-mark
Old 03-01-2005, 08:11 PM   #11 (permalink)
Working hard?
im going to run with the stock setup for a while
thanks for input
Old 03-01-2005, 08:16 PM   #12 (permalink)
VeeZed
JetspeedCamry's Avatar
View JetspeedCamry's Photo Gallery
1000 for a transmission?? I paid 450 for my FULLY rebuilt E153....
1988 Toyota Camry 2VZ-FE E153
1972 Ford Mustang Sprint "F" 351C-2V 4SPD
1973 Ford Mustang Mach 1 "Q" 383C-4V FMX
JetspeedCamry is offline   Reply With Quote
Old 03-01-2005, 08:18 PM   #13 (permalink)
Working hard?
^^^ instalation? i guess im over estimating how much did u pay for instal? i might get it done 4 me as i have no experience or time
Old 03-01-2005, 08:28 PM   #14 (permalink)
VeeZed
Oh...no thats to buy it..ill install it myself.
Old 03-01-2005, 08:31 PM   #15 (permalink)
Working hard?
yeh i have 2 jobs so i only work sleep and eat on every day but saturday. so i dont have the time. otherwise i would do it myself
