Engine revs really high on start up.... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-01-2005, 08:32 PM   #1 (permalink)
MadDawg's Avatar
View MadDawg's Photo Gallery
3rd Generation Engine revs really high on start up....
(1996 camry 5sfe) Sorta interesting... for the past couple weeks, every other morning or durring the day or at night sometimes, i'll start it up, and like normal cars, it'd rev a little past 1000rpms... well huh, when i turned the key over, it did that, but revved up to 2500rpms, then revved down to 1000 then back up to 2000 rpms, then back and forth and went back to normal...
huh.... i do have a short ram intake, no idea why it'd do that...
BUT... i dont know if this would account for it, the car is coming really close to getting an oil change, if in fact, i believe i passed the oil change time... i checked the oil... it was a full quart low and dark black... would that also explain why it would get really bogged down when i'd hit the pedal to the floor? i almost got into an accident the other day cause the car didnt do what it normaly does...
i should also say, the valve covor by the fuel injector is leaking oil...
MadDawg is offline   Reply With Quote
Old 03-01-2005, 09:20 PM   #2 (permalink)
em_
View em_'s Photo Gallery
that sucks Dawg i was asking my self teh same question
once i started my car and the engine went at 3700rpm i was like what the fuck ?
it never dit it again
at least the engine was hot
em_ is offline   Reply With Quote
Old 03-01-2005, 10:33 PM   #3 (permalink)
Auto-Cross Addict
SmokingTires's Avatar
View SmokingTires's Photo Gallery
My car goes up to 2000RPM until it cools. That's just how it's always been. Runs fine to me, so it doesn't seem like that big of a problem.
'88 Toyota MR2 N/A - Sold
'99 Miata Sport - Sold
'85 Corolla GT-S - Sold
'02 MR2 Spyder - C-Stock car
SmokingTires is offline   Reply With Quote
Old 03-01-2005, 11:01 PM   #4 (permalink)
97camryman's Avatar
View 97camryman's Photo Gallery
I have never heard of that before. Going a little over on an oil change is not that bad. It would take 1000's of miles past change to make the oil turn to sludge an that would just kill the motor not make it rev higher.
97camryman is offline   Reply With Quote
Old 03-02-2005, 01:21 AM   #5 (permalink)
View Neatride2's Photo Gallery
Engine Rev at start up?
I read somewhere that a faulty IAC valve can cause engine rev up at start up. May be worth checking it out. Good luck.
Neatride2 is offline   Reply With Quote
Old 03-02-2005, 03:01 AM   #6 (permalink)
MadDawg's Avatar
well, she's comin close to 10 years old, and the only thing thats ever been replaced on it, is 3 cv boots and the timing chain....
Old 03-02-2005, 11:50 AM   #7 (permalink)
Auto-Cross Addict
Does the car run fine after it's warm? If it does, than I think it's nothing to worry about
But I believe that is a Toyota device which uses engine temp to help judge idle. And when it is so cold, it revs it higher to heat the engine faster.
Old 03-02-2005, 03:55 PM   #8 (permalink)
View karazy's Photo Gallery
The idle should never go above about 1200 rpm thru the IAC or idle up. A cold start at 2500 could definitely do damage to the engine. I still have trouble getting used to the 1800rpm start up of the gen9 rollas.
The cause could be many things, but egr/vacuum leak might be a good place to start. It could be the ecm acting up, but you probably don't want to here that.
karazy is offline   Reply With Quote
Old 03-02-2005, 03:59 PM   #9 (permalink)
That One Guy...
View Corollacrazy42's Photo Gallery
well if ur personally worried about it.. take it in.. that would be the best advice, maybe they can try and help with the problem
Corollacrazy42 is offline   Reply With Quote
Old 03-03-2005, 07:49 PM   #10 (permalink)
MadDawg's Avatar
i just checked my gas mileage right now, i'm getting under 15mpg right now...
Old 03-03-2005, 11:13 PM   #11 (permalink)
Auto-Cross Addict
I get 27mpg and my car idles at 2k on start up in cold weather.
Old 03-04-2005, 01:57 AM   #12 (permalink)
MadDawg's Avatar
i think its the dark clunky oil
