Whats killing my gas mileage?? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-01-2005, 11:40 PM   #1 (permalink)
happy 500k
View lil_ta's Photo Gallery
3rd Generation Whats killing my gas mileage??
Hey all,
I got a 94 camry XLE 4cyl. I get about 245 miles to a full take with mix driving.. the car got bout 234K its got bosal headers and "fart can".. Could there be and issue with the O2 sensor possibilities?? I've changed my wires/cap/spark plugs/etc.. not much of a change..
Anything would help at this point thanks
Andy
lil_ta is offline   Reply With Quote
Old 03-01-2005, 11:45 PM   #2 (permalink)
Toyota Nation Wanderer
View Camry726's Photo Gallery
Lead foot...
My gen 3 died...now I drive a gen 4, I have a feeling the next will be a gen 5...
Camry726 is offline   Reply With Quote
Old 03-02-2005, 12:03 AM   #3 (permalink)
Toysrme's Avatar
View Toysrme's Photo Gallery
Cool
What he said, the gas pedal has the most to do with it.
o2 sensor. You can check them. Bring the car up to temperature at 2000rpm, the voltage should be at 450mv on the simulated signal.
Reading from the o2 sensor itself, it should swing between around 420 and 480mv at least 8 times a second.
A dead o2 sensor will read 450mv all the time.
AIM/Yahoo Toysrme257th
Now with Turbo!
Old 03-02-2005, 03:05 AM   #4 (permalink)
MadDawg's Avatar
View MadDawg's Photo Gallery
stop revving her past 5000rpms
MadDawg is offline   Reply With Quote
Old 03-02-2005, 06:39 AM   #5 (permalink)
amerikim's Avatar
View amerikim's Photo Gallery
City driving makes a 50% difference in my car's consumption.
Also tears the brakes and tires up. You can imagine the rest.
However stop using the tank as an indicator. Not a good way for gauging consumption. Just take your milage and divide by how much you pumped in.
For example; Divide 234 miles on odo by 15.456 gallons at pump = 15.14 mpg.
Lots of cel phones have calculators.
old faithful
amerikim is offline   Reply With Quote
Old 03-02-2005, 06:57 AM   #6 (permalink)
amerikim's Avatar
Add on;
If you have 100000 miles on your odo, you car has consumed 6605 gals of gas.
old faithful
Old 03-02-2005, 10:54 AM   #7 (permalink)
TN の がしょう
xpeed's Avatar
Gameroom cash: $591657
iTrader Score: 7 reviews
View xpeed's Photo Gallery
Originally Posted by amerikim
Add on;
You can edit your previous post you know.
I have to say it's either your a lead foot or the pistons or ports needs to be cleaned or something. Don't know what I'm saying, but that' my opinion.
1997 カムリ 5-spd *daily driver* Tokico HP - Tein S-Tech - TRD Kit - TRD FSB - ARC - 18" Enkei OR52 - Project Kics R40 - Custom Exhaust - Whiteline 20mm Rear Sway Bar
2003 Infiniti FX35 Sport Package - Metallic Copper
1996 Avalon MCX10 1MZ-FE
http://www.cardomain.com/ride/3900268/1997-toyota-camry
xpeed is offline   Reply With Quote
Old 03-02-2005, 03:12 PM   #8 (permalink)
Gameroom cash: $304355
Along with the O2 sensors mentioned above, also use the digital volt/ohmeter to check the coolant temp sensor. Toyota refers to it as the ECT sensor. It tells the ECU how cold or warm the engine is by way of the coolant temperature and the ECU adjusts the fuel mixture richer or leaner accordingly. A failing coolant temp sensor could be telling the ECU the engine is cold when it's in fact warm. This can waste a lot of fuel.
Let's also not forget the obvious; a little bit of brake drag can really affect mileage. On level ground, put the car in neutral with the e-brake off and try to push the car by hand. How hard is it to push? If it's real hard, jack up the front first and then the back end (with the e-brake off) and see how hard it is to rotate each tire by hand. If one wheel is noticeably harder to turn then the others, you have found an offending brake.
Mike
Old 03-02-2005, 06:42 PM   #9 (permalink)
View mmurray70's Photo Gallery
What kind of MPG are you guys normally getting? My 92 4cyl seems to get between 20 and 25 mpg depending on the type of driving. Usually close to 350 miles per tank. That about right?
mmurray70 is offline   Reply With Quote
Old 03-02-2005, 09:41 PM   #10 (permalink)
happy 500k
3rd Generation
thanks guys for your inputs, I have been using sea foam for a while now but.. I see there are slight improvements but it just returns to it nomal state. Do any gas additive do anything? I just drove my car in one sitting to the beach.. I got about 260 miles on a tank.. from F to the light turns on.. Or could it be a dirty fuel filter? I got an CAi with an intercooler looking intake?? ehh ..
Old 03-02-2005, 09:53 PM   #11 (permalink)
Toysrme's Avatar
Cool
Not really. Most are designed to help clean the fuel system from small debris/build-up.
If there is nothing blocking, or gunking the fuel system, then the additives don't appreciably do anything.
Fill the tank with 87 if you use premium, While it's filling reset the ECU (Pull the EFI fuse for 10 seconds) See if it's any better.
Now with Turbo!
