Brake pad shim question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-02-2005, 11:27 PM   #1 (permalink)
Triple A Whore
Edmond's Avatar
View Edmond's Photo Gallery
I don't know if it's actually called a shim or not but it's the little metal plate between the pad and the caliper piston.
I have two very thin plates on the front of my Camry. Am I supposed to have two or just one plate?
Edmond.
Edmond is offline   Reply With Quote
Old 03-02-2005, 11:31 PM   #2 (permalink)
View robehsi's Photo Gallery
2 pads per caliper, 1 shim for each pad so 2 shims each caliper = correct. my aftermarket brakes have a small underneath shim and a top shim for each pad.
robehsi is offline   Reply With Quote
Old 03-02-2005, 11:41 PM   #3 (permalink)
Triple A Whore
Edmond's Avatar
Mine has two shims on each pad, 4 on each caliper. Think that could cause some squeaking?
Edmond.
Old 03-02-2005, 11:45 PM   #4 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $396560
iTrader Score: 13 reviews
it depends on the gen of camry you have
Yes, the gen3s (at least hte v6s, don't know about the 4bangers) have 4 shims to each brake pad. Two on each side, same for front and back.
squeaking can becaused by either rusty/old shims, or a lack of anti-squeal oil stuff (forgot what its called)
if your shims are in bad shape, get new ones from the dealer- it will come with anti-squeal stuff
if they're in perfectly good condition, then go to your local auto shop and ask for anti-squeal lubricant - it usually comes in small packets
HaHa
Old 03-03-2005, 12:00 AM   #5 (permalink)
Triple A Whore
Edmond's Avatar
I was getting this annoying squeaking for the past few weeks and finally got around to doing something about it last Friday. I just blew some air into the rear brakes and that seemed to solve the problem for a few days.
It came back a couple days ago and I thought that it could be the front brakes since I blew some air onto the rear brakes so there shouldn't be any dust or anything like that back there.
I'll have to pull all 4 tires off this weekend and examine the problem. The squeaking is getting on my nerves.
Edmond.
Old 03-03-2005, 04:07 AM   #6 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
^ Remove the brake pads. Clean the pads, shims, and rotors with brake parts cleaner.
Apply disc brake goop onto the back of the pads and shims. You can buy it in little packages, bottle, or spray can.
Reinstall.
"Skoolin' the unlearned!"
Old 03-03-2005, 11:59 AM   #7 (permalink)
Triple A Whore
Edmond's Avatar
Reinstall.
Thanks for the advice. I will do that tomorrow.
It was just having the squeaking when I didn't step on the brake. But today, I noticed that on occassion, it would also squeak from the other side when I stepped on the brake.
They're Bosch brake pads, if that would have anything to do with it.
Edmond.
Old 03-03-2005, 02:54 PM   #8 (permalink)
View fe519's Photo Gallery
it might be your brake pads. I got a 98 camry v6 and bought pads from kragen (and not even the cheap pads) and they squeaked like sh*t! This was about 3 years ago when the car was relatively new. I got so fed up that I bought OEM pads and they dont squeak at all. You might just wanna go with original pads. Sometimes the rotor is not even and cause it to squeak but when I installed it in my camry, it only had about 30k on it.
fe519 is offline   Reply With Quote
Old 03-03-2005, 05:15 PM   #9 (permalink)
Triple A Whore
Edmond's Avatar
I just put the pads and rotors on last October. It didn' start squeaking until a month ago.
How much are OEM pads? I don't really want to spend much.
Edmond.
Old 03-04-2005, 04:11 PM   #10 (permalink)
View steve97's Photo Gallery
OEM pads $45 + shipping. Not bad
Akebono ProAct Ceramic pads $61 + shipping
steve97 is offline   Reply With Quote
