torque settings for sway bars - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-03-2005, 03:32 AM   #1 (permalink)
View moojuice's Photo Gallery
Question torque settings for sway bars
Hello,
Does anybody know how much torque I'm supposed to use when installing a rear sway bar on a 1990 camry? Need settings for bushing bracket and both ends of endlink. Haynes and Chilton don't really specify and I don't want to break a bolt. Damn, I hate being new at this.
thanks for any info,
moojuice is offline   Reply With Quote
Old 03-03-2005, 12:58 PM   #2 (permalink)
View Calvin327's Photo Gallery
Really can't tell how many lbs of torque you need. Just becareful doing taking those bolts off and don't use too much force.
Calvin327 is offline   Reply With Quote
Old 03-04-2005, 05:44 AM   #3 (permalink)
thanks anyways......
Old 03-04-2005, 06:39 AM   #4 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
14 ft. lbs. on the bushing brackets.
47 ft. lbs. on the endlinks.
The specs are from a Chiltons manual, page 8-26. Don't know why you couldn't find them.
"Skoolin' the unlearned!"
Old 03-04-2005, 06:53 AM   #5 (permalink)
The Other White Meat
terrastrife's Avatar
for bushings it more dependand on teh material, if theyre poly make sure you dont squash em up.
terrastrife is offline   Reply With Quote
Old 03-04-2005, 07:29 AM   #6 (permalink)
Grenaded piston
88 LE's Avatar
^ In this case it doesn't matter. Your tighten down the bracket, not the bushing.
