turbo issue - Toyota Nation Forum : Toyota Car and Truck Forums
Closed Thread
Old 03-03-2005, 07:25 PM   #1 (permalink)
View lifeisviewtiful's Photo Gallery
turbo issue
ok now i know a t25 is a very small turbo, i am just going for a little boost. what i want to know is if i get one would i be able to fit it onto any engine(namely my 70-afe) as long as i get a manifold with the matching flanges?
lifeisviewtiful is offline
Old 03-03-2005, 07:30 PM   #2 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
getting the manifold is going to be the fun part
fredk is offline
Old 03-03-2005, 08:01 PM   #3 (permalink)
i was thinking the exact same thing. any car you kno i can take one off of that would fit. a jdm model maybe
Old 03-03-2005, 08:12 PM   #4 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
nope
fredk is offline
Old 03-03-2005, 08:15 PM   #5 (permalink)
Always Under Construction
View whocares04's Photo Gallery
y bother w/ a little turbo, y not a medium sized turbo and turn boost down then be able to turn it up....
-Matt
When in doubt, use the search function (link)...no one is spoon fed...
whocares04 is offline
Old 03-03-2005, 08:46 PM   #6 (permalink)
97camryman's Avatar
View 97camryman's Photo Gallery
Get a flange adapter made. Should be like 50-100 bucks. Use a tee adapter on oil pressure sensor to make an oil feed line for turbo, Return line needs to be tapped into oil pan. Coolant lines run from something else. Exhaust shop will weld you up a DP to the exhaust and then you need a custom intake pipe made. Replave MAP sensor, bigger fuel pump, bigger injectors, SAFC2 to tune fuel curve is needed. Boost gauge, EGT and oil pressure gauges are nice. Blow off valve needs to be flange matched to intake pipe, wastegat might be needed. Boost controller and a few other thigs like a FPR and possibly small intercooler might be needed.
97camryman is offline
Old 03-03-2005, 08:55 PM   #7 (permalink)
very well put 97 camry man thx alot.
Old 03-03-2005, 09:02 PM   #8 (permalink)
Originally Posted by 97camryman
Get a flange adapter made. Should be like 50-100 bucks. Use a tee adapter on oil pressure sensor to make an oil feed line for turbo, Return line needs to be tapped into oil pan. Coolant lines run from something else. Exhaust shop will weld you up a DP to the exhaust and then you need a custom intake pipe made. Replace MAP sensor, bigger fuel pump, bigger injectors, SAFC2 to tune fuel curve is needed. Boost gauge, EGT and oil pressure gauges are nice. Blow off valve needs to be flange matched to intake pipe, wastegat might be needed. Boost controller and a few other thigs like a FPR and possibly small intercooler might be needed.
i was thinking all of what you said bro plus a transmission cooler, bov was a must tho. besides whats the use of having a turbo if you can't let eevryone know you have one. pssssssssst lol. how much you think i'll spend on reinforcing the tranny, torque converter ?
Old 03-04-2005, 02:48 AM   #9 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Cross posting is not allowed.
http://www.toyotanation.com/forum/se...r&userid=23401
"Skoolin' the unlearned!"
88 LE is offline
Closed Thread
