where can i find the hole? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-21-2002, 06:10 PM   #1 (permalink)
View camry phaze's Photo Gallery
i just got a jbl amp and i plan to hook it up to my infinity kappas inside my car. but before i do it i want to know from you guys where the hole is so that i can route the power wire of the amp to the car battery under the hood? can someone help me out here i have a 99 camry. thanks alot guys.
modding a car that no one thinks is possible, is the art of being original. Go camry!
camry phaze is offline   Reply With Quote
Old 07-21-2002, 07:37 PM   #2 (permalink)
Phi
Whine Connoisseur
Phi's Avatar
View Phi's Photo Gallery
These instructions are for a '92-'96 Camry. I'm not sure if it's the same for '99, but if you have the time and patience and wan't to avoid drilling a hole in the firewall, this is the way to go.
This was posted on CMPL by Gibson99; http://www.camryman.org/cgi-bin/config.pl?read=168738
Pull the driver front wheel, and the fender liner. you'll see the rubber grommet that has factory wires going into the cabin, and a plastic ring going into the engine compartment.
Other than the above route, your only other choice is to drill through the firewall (from what I know). What ever method you use, do yourself a favour and use 4ga pwr wire if possible (ask Camry2000 :wink: ) and don't forget to use a gromet to prevent the wire from being severed and starting a fire in the car.
Besides that, welcome to TN![/i]
Phi is offline   Reply With Quote
