Wiring diagrams - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-05-2005, 06:54 AM   #1 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
2nd Generation Wiring diagrams
Just wondering if anybody has a Toyota repair manual for a gen 2 w/3S-FE.
If so can you check something for me? I need to know if it has a diagram and schematic of everything that plugs into the fuse box (the one under the hood).
I have a Toyota ewd (electrical wiring diagram) manual for a 88 Camry w/3S-FE. It only shows the relays, fuses, and plug numbers. No schematics of the stuff that plugs into the fuse box.
What I'm looking for is something like this:
http://www.gtfour.ca/st185_fusebox.JPG
http://www.gtfour.ca/st185_fusebox_inner_circuit.JPG
My ewd manual shows something like this, except theres no pin numbers for the plugs:
http://www.gtfour.ca/ST16x_JB2.jpg
P.S. No Haynes/Chiltons crap. I'm looking for diagrams from a factory (Toyota) repair manual aka BGB or TSRM.
"Skoolin' the unlearned!"
Old 03-06-2005, 07:34 AM   #2 (permalink)
Beams SV21
da_horse's Avatar
View da_horse's Photo Gallery
Hey 88LE,
i have the engine repair manual but its not really specific, it does have a section on the 3sfe but i cant find the diagrams that you want. all i have are the following sections for 3sfe:
- Engine Mechanical
- EFI System
- Ignition System
- Starting System
so as you can see mine is very general...
if there's anything in those sections then let me know. Its funny that you dont have it in your EWD tho, the Engine manual wouldnt cover this would it?
Cheers
Huy
1989 BEAMS 3S-GE SV21 Camry
2003 ST246 Caldina GT-Four N
da_horse is offline   Reply With Quote
Old 03-06-2005, 08:20 AM   #3 (permalink)
Grenaded piston
88 LE's Avatar
Yeah.
The picture that it shows of the fuse box is very plain. It just shows the relays, fuses, and plugs.
The other diagrams/schematics refer to stuff in the fuse box. But no schematic just for the stuff in the fuse box.
If I can't find a schematic I'll have to break out my DMM and trace everything that plugs into the fuse box. Its gunna be a pain in the ass.
I'm not sure.
I'll have to call Toyota customer service during the week and ask them.
Old 03-06-2005, 08:40 AM   #4 (permalink)
Beams SV21
da_horse's Avatar
go on, do it, break out the DMM, you know you want to
is there any particular item you need the info for?
Cheers
Huy
Old 03-06-2005, 08:58 AM   #5 (permalink)
Grenaded piston
88 LE's Avatar
Haha... If I have to, I will.
Its not a big deal. I majored in electronics and I use to work as a installer (car stereo & alarms). So I'm sure I'll be able to figure it out.
Just trying to figure out the wiring for a 3S-GTE swap ahead of time.
I haven't been able to find any wiring info for a 3S-GTE swap into a gen 2.
Old 03-06-2005, 01:48 PM   #6 (permalink)
View jefe's Photo Gallery
Hey 88LE,
I have the Factory Wiring Manual and also the pullout diagrams in the Factory Repair Manual. Unfortunately I don't have access to a scanner.
You need J/B and R/B No. 2 info. right?
What specifically?
I can try to draw it and label it with a photoshop program or equivalent.
jefe is offline   Reply With Quote
Old 03-07-2005, 06:02 AM   #7 (permalink)
Grenaded piston
88 LE's Avatar
^ Just J/B No. 2 (the fuse box under the hood).
I need something like this:
Old 03-07-2005, 09:35 AM   #8 (permalink)
Here is the 1st part. Let me know if this is going to work for you because it took me awhile to do it!
Also, I can e-mail it to you if you want. PM me.
Old 03-07-2005, 09:53 AM   #9 (permalink)
Here is the next view. I will try to see if I can find a scanner at work tomorrow to use because the inner circuit is gonna be a bear to draw out.
Old 03-07-2005, 11:08 AM   #10 (permalink)
Grenaded piston
88 LE's Avatar
^ Thanks.
Those drawings will work. However if you can scan the diagrams, that would be even better.
P.S. My ewd manual shows another plug thats not in the 2nd diagram you drew. Its labeled "2D" in my manual.
Old 03-07-2005, 12:43 PM   #11 (permalink)
Hey man, sorry about that. (Frustrating as hell when ppl make a 1/2 ass post when you need the correct info, right?.....) I was trying to be as careful as I could but I had a lot going on this a.m.
Anyway, you are right. There is another plug, with just a "1" in it that is labelled 2D.
I will try to track down a scanner tomorrow.
Old 03-08-2005, 08:21 AM   #12 (permalink)
Grenaded piston
88 LE's Avatar
Don't worry about it. Its just one plug with a single wire.
Kewl. Thanks.
P.S. I'll scan the diagram of the fuse box out of my ewd manual.
Old 03-08-2005, 12:10 PM   #13 (permalink)
Grenaded piston
88 LE's Avatar
This is the only diagram of the fuse box in my ewd manual:
Old 03-08-2005, 06:15 PM   #14 (permalink)
I'm a Mac
zoni's Avatar
View zoni's Photo Gallery
what i leanred with my 5sfe - 1mz swap was to wait until you have the wiring harnesses in your hands and you can actually see what you have. i tried to plan it out ahead of time and everything was remotely straight forward, but once you get the things, you will have extra wires that you need to figure out and random plugs that you have no place for... being prepared is good, but it can only get you so far. most of the stuff will be almost common sense for you 88, but i'd wait till you have some harnesses to play with.
Dave Zoni
Latest 3S-GTE Swap Pics
zoni is offline   Reply With Quote
Old 03-09-2005, 09:09 AM   #15 (permalink)
http://img24.exs.cx/img24/8302/innercircuitd41fi.png
http://img24.exs.cx/img24/541/headrhfor8ba.png
Hope this helps!
