Alternator question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-07-2005, 06:10 AM   #1 (permalink)
View treecitybusa's Photo Gallery
2nd Generation Alternator question
Did the search, did not find what I needed.
Is the alternator located in the same location in a non-a/c 2.5l compared to a 2.5 with a/c. Reason is that I want to bypass my ac, not working and pulley is about to fall off, without having to replace it.
treecitybusa is offline   Reply With Quote
Old 03-07-2005, 06:52 AM   #2 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
The alternator is in the same location. Regardless if you have a/c or not.
You need a shorter belt. IE: crank pulley to alternator belt for a 2VZ-FE without a/c.
"Skoolin' the unlearned!"
Old 03-07-2005, 07:57 AM   #3 (permalink)
Thanks 88! You wouldn't happen to have a belt routing diagram for both would you?
Kenwood CD Receiver / Kenwood Graphic EQ
FRONTS - JL Audio XR653CS - 3 speaker comps
REARS- Rockford Fosgate - 2 speaker comps
AMP - Kenwood - 400/4
TRUNK - JL Audio Powerwedge - 3 10" subs
AMP - JL Audio 500/1
Old 03-07-2005, 11:00 AM   #4 (permalink)
Grenaded piston
88 LE's Avatar
http://www.autozone.com/servlet/UiBr...3d8013b56d.jsp
1. Crank pulley --> alternator
2. Crank pulley --> alternator --> a/c compressor
Old 03-07-2005, 11:47 AM   #5 (permalink)
88 -
I went and got the non a/c belt and the ribs width is different. I believe the ac, the one i have now, is 7 rib. the one I got was only for a 2 or 3 rib.
Also that link that you sent says crank/pwr steering. Do you have any more advice.
Old 03-07-2005, 07:47 PM   #6 (permalink)
2nd Generation
Has anyone bypassed the a/c compressor on a 2vz??
Old 03-07-2005, 08:16 PM   #7 (permalink)
Mad Scientist-In-Training
toyrolla's Avatar
View toyrolla's Photo Gallery
2nd Generation
I've done it for the 3SFE, but I had to move the compressor pulley back to clear a path between the alternator and crank pulleys.
The procedure I did is assuming that you're not removing the A/C compressor.
What I did was loosen the compressor and wedge the extra gap to give it enough clearance to clear the path of the belt.
You can use some bolts or a series of washers to wedge in the extra gap.
I loosened it to give about 3/4-to-1 inch of clearance from the A/C pulley.
Once you've immobilized the compressor and you have a clear path between the alternator and crank pulleys, install the non-A/C belt.
Good luck Dude and let us know how you make out.
Regards,
Toyrolla
__________________________________
88 I4 Slushie *sold*, 89 I4 5Sp *sold*, 89 V6 5Sp *sold*, 82 Corolla, 72 Datsun 510, 88 Toyota Minitruck.
toyrolla is offline   Reply With Quote
Old 03-07-2005, 11:35 PM   #8 (permalink)
Camry's are so F'ing sick
best camry ever's Avatar
View best camry ever's Photo Gallery
How often do the alternators go on the 1ma-fe? I've had to replace the alternator on every car I've owned. Hopefully I wont have to on the Camry.
best camry ever is offline   Reply With Quote
Old 03-08-2005, 09:19 AM   #9 (permalink)
Grenaded piston
88 LE's Avatar
Theres 2 accessory belts.
1. Crank pulley --> power steering pump.
2. Crank pulley --> alternator --> a/c compressor. Or crank pulley --> alternator.
You'll be dealing with #2.
I would follow toyrolla's advice about shimming the a/c compressor away from the block. Use some washers on each bolt (theres like 3 or 4 bolts) between the block and a/c compressor.
Are you sure that you bought the correct belt?
The crank pulley --> power steering pump belt is smaller then the crank pulley --> alternator belt.
Crank pulley ---> alternator belt is also wider.
Old 03-08-2005, 10:39 AM   #10 (permalink)
toyrolla's Avatar
THAT'S the word I was looking for when I posted...
Regards,
Toyrolla
Old 03-08-2005, 08:16 PM   #11 (permalink)
Done !!!
Well, it took just 10-15 min to do. I didn't have to move the compressor out of the way. About a 1" clearance.
88- The belt that they gave me originally was for the power steering pump. For those interested, the non-a/c belt for the V6 is a Kelly Springfield 370K6 belt from Autozone.
The car does seem a bit snapper now. Hope this helps out. Thanks to all for the responses!
Old 03-08-2005, 08:45 PM   #12 (permalink)
poor college student
userlain's Avatar
View userlain's Photo Gallery
Why did you bypass your a/c copressor?
'91 Camry @ ~162,900 miles
userlain is offline   Reply With Quote
Old 03-09-2005, 09:05 AM   #13 (permalink)
Grenaded piston
88 LE's Avatar
Kewl.
Good to hear that you got it done.
Idiots.
