Vent selector light and fan speed light don't work - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-07-2005, 07:49 AM   #1 (permalink)
View TonyD's Photo Gallery
I need help to replace these lights. I have done searches but can't seem to find a simple answer to replace these lights on a 1992 Camry sedan. Would somebody please tell me?
Thanks
TonyD is offline   Reply With Quote
Old 03-07-2005, 08:08 AM   #2 (permalink)
View wanman75's Photo Gallery
It's about a 20 minute job, and you need a small (type 37 or 74) bulb (does anyone else have a definitive answer on the bulb type? Both fit, but I'm not sure of OEM voltage or amperage).
Getting to the bulb is fairly straightforward:
1. Pop the surround on the radio using a taped flat screwdriver near the cigarette lighter, and then on the opposite side.
2. Once that is off, take the dash trim out. There are two screws in front of the instrument cluster, and two near the radio (one on either side). Be careful of the wiring for the power mirror and dimmer controls.
3. A screw on either side of the HVAC control will let you take that out. Pull the knobs off the fan and temp controls. You will see 6 tabs (3 on top, 3 on the bottom) that hold the face plate to the rest of the unit. Pop off the faceplate carefully, and you should see the bulb behind that.
4. Assembly is the reverse.
--- Procrastination ---
"Hard work pays off over time, but laziness always pays off now."
wanman75 is offline   Reply With Quote
Old 03-07-2005, 06:43 PM   #3 (permalink)
rusty9's Avatar
Gameroom cash: $441505
View rusty9's Photo Gallery
hehe i just did this 2 weeks ago. its pretty straight forward...the bulb is the hardest to find :P
rusty9 is offline   Reply With Quote
Old 03-07-2005, 08:31 PM   #4 (permalink)
not your average bear
View justchillinjefe's Photo Gallery
ive got the same problem, i'll give it a try next time i can make it to walmart for the bulb
justchillinjefe is offline   Reply With Quote
Old 03-07-2005, 09:42 PM   #5 (permalink)
rusty9's Avatar
you wont find it at walmart =)
Old 03-08-2005, 08:37 AM   #6 (permalink)
ive got faith, i got my corner lights, license plate lights and dome light at walmart. If not i'll check out napa.
