E153 bolts up to 5S-FE? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-09-2005, 11:39 PM   #1 (permalink)
97camryman's Avatar
View 97camryman's Photo Gallery
Will an E153 5 speed bolt up to a 5S-FE? It seems that since the E153 bolts up to a 3S block it should bolt up to a 5S-FE since the two blocks share bolt patterns. Can anyone confirm this?
97camryman is offline   Reply With Quote
Old 03-10-2005, 12:30 AM   #2 (permalink)
N/A bites
Tercel GTS's Avatar
yes they swap
雄のハヤブサ
Tercel GTS is offline   Reply With Quote
Old 03-10-2005, 12:18 PM   #3 (permalink)
I'm a Mac
zoni's Avatar
View zoni's Photo Gallery
yes. for the proper 5sfe/e153 clutch/flywheel setup, you need:
-5sfe flywheel
-5sfe pressure plate
-3sgte clutch disc
if you are putting this in a 97 camry i4, which is what i assume from your name...
besides the clutch/flywheel setup you will need:
-v6 drivers side axle (gen 3 or 4)
-on the passenger side you need 3sgte (mr2 turbo OR celica alltrac) inner axle
-and gen 3 camry v6 outer axle.
-wheel hubs(steering knuclkes)
-calipers
-and rotors.
i might still be worried about the carrier bearing setup. Im not sure that the mr2 inner axle carrier bearing fits into the 5sfe motor mount. Wraith would probably be the only person to know this for sure.
Dave Zoni
Latest 3S-GTE Swap Pics
zoni is offline   Reply With Quote
Old 03-10-2005, 07:40 PM   #4 (permalink)
97camryman's Avatar
Thanks Zoni, I am planning my 3S GTE swap and I have $1500 saved up so far and I was like hmm, could I drop in the tranny now and save myself work later? I already have a clutch pedal and master cylinder installed and I bought a shifter and cables from Mobes so I'm getting anxious to put it all in! I figure I can find an E153 in decent shape for around $900 and then axles are about $200 each, hubs, calipers, I want it in now I don't want to wait 7 months!
Old 03-11-2005, 04:49 AM   #5 (permalink)
I'm a Mac
zoni's Avatar
i wouldnt change to e153 now... do it when you swap the motor... you basically have to take out the motor to swap the tranny, so i'd just wait till you have a motor. you like taking th motor out? if so then do it twice, if not, do it once.
Dave Zoni
Old 03-11-2005, 11:37 AM   #6 (permalink)
97camryman's Avatar
Yeah thats what I will probably end up doing. Its just tempting thats all.
Old 03-16-2005, 12:42 AM   #7 (permalink)
View Juggernaut's Photo Gallery
wouldnt you be able to use the half shafts and hubs and sutch from a ce modle, didnt they have the e153 trans?
Juggernaut is offline   Reply With Quote
Old 03-16-2005, 10:17 AM   #8 (permalink)
I'm a Mac
zoni's Avatar
nope
thats the s54.
just because its standard doesnt make it a e153.
s54 is the standard tranny used with the 5sfe.
Dave Zoni
