Sparkplug Boot - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-11-2005, 12:08 PM   #1 (permalink)
Post Hoc Ergo Propter Hoc
Bishop13's Avatar
View Bishop13's Photo Gallery
3rd Generation Sparkplug Boot
I have this nagging problem w/ the sparkplug wireboot for the #4 cylinder (or #1, the one on the passenger side). Everytime I take off the wire, the boot at the bottom comes off and gets stuck on the damn spark plug. Anyone have this problem? Are there any adverse effects of leaving it off?
Capitalization is the difference between helping your uncle Jack off a horse, and helping your uncle jack off a horse
1997 Toyota Camry LE / 2001 Land Rover Discovery II / 2006 Audi A4
http://www.flickr.com/photos/henryenriquez/
Bishop13 is offline   Reply With Quote
Old 03-11-2005, 12:11 PM   #2 (permalink)
sargdesigns
arcasmachineracing's Avatar
View arcasmachineracing's Photo Gallery
Buy new wires and solve the problem.
Brandon
arcasmachineracing is offline   Reply With Quote
Old 03-11-2005, 12:31 PM   #3 (permalink)
Me and my Bebe, Bianca
CamryPunk's Avatar
View CamryPunk's Photo Gallery
yeah I had the same problem before. I did what arcasmachineracing did... bought new ones.
Yukio Taira
-1992 4 door Bomex'ed out, Nitrous Express Sport'n, Rippmods SuperCharged Camry
-1992 4 Door EX Honda Civic 5 spd.
-2002 Subaru WRX Wagon... full JDM goodies. My new show car.
CamryPunk is offline   Reply With Quote
Old 03-11-2005, 01:04 PM   #4 (permalink)
Bishop13's Avatar
I've done that...3x. It does it to every single set..and its just that one plug. At first I thought it was cuz there was oil leaking or whatever, but when my headgasket blew and got the block replaced, it still did it! So its done it to 3 sets of wires and 2 engines
Old 03-11-2005, 09:38 PM   #5 (permalink)
VeeZed
JetspeedCamry's Avatar
View JetspeedCamry's Photo Gallery
After 3 sets and 2 engines...you must not be doing something right....
1988 Toyota Camry 2VZ-FE E153
1972 Ford Mustang Sprint "F" 351C-2V 4SPD
1973 Ford Mustang Mach 1 "Q" 383C-4V FMX
JetspeedCamry is offline   Reply With Quote
Old 04-16-2006, 12:32 PM   #6 (permalink)
View toddf's Photo Gallery
boot stuck
I just ran into the same problem with my daughters 94 4 cyl. Buying new wires wont get the end of the boot out of the recessed hole. I need to change the plugs and the boot wont let me get the socket on the plug to remove it. How do i get the end of the boot out of the hole? any help is appreciated
Thank you,
Todd
toddf is offline   Reply With Quote
Old 04-16-2006, 01:10 PM   #7 (permalink)
Bishop13's Avatar
What I ended up doing was getting a long piece of hose that fits around the top part of the park plug (I think it was a heater hose), snaking it down the hole and around the spark plug. Once its snug around the plug, then turn the hose to unscrew the plug and the boot end should come up along with the spark plug. Try to straighten out the hose first, it makes it a lot easier
You're using Bosch spark plug wires, aren't you? If you are, get another brand..this problem only happened to me with Bosch wires.
Old 04-16-2006, 06:29 PM   #8 (permalink)
View marc780's Photo Gallery
Put a dab of electrical contact grease before you reinstall, this might help some little bit
Old 04-16-2006, 06:34 PM   #9 (permalink)
Bishop13's Avatar
^^ I dunno if that would help. I've tried doing that prior and it still happens. The problem seems to be that the adhesive that's used on the boot melts off.
Old 04-16-2006, 07:22 PM   #10 (permalink)
*Place Title Here*
View Go4shoped's Photo Gallery
dont take it off. problem solved
Go4shoped is offline   Reply With Quote
Old 04-16-2006, 08:52 PM   #11 (permalink)
View tarbasd's Photo Gallery
3rd Generation
Same happened to me. I changed the wires. Put a bit os silicone on the boots.
To get it out, make a hook from a piece of chicken wire or some other hard wire.
tarbasd is offline   Reply With Quote
Old 04-16-2006, 10:33 PM   #12 (permalink)
*Place Title Here*
actually this happened to me too. im not sure if it was on my camry or tacoma but it wasnt just 1. it was all 4. i just bought some really long-nosed pliers and pulled it off.
luckily for me i dont take mine off too often and my grandfather owns a parts shop.
Old 04-17-2006, 04:48 AM   #13 (permalink)
Odaiba Romance
shingouki808's Avatar
iTrader Score: 8 reviews
View shingouki808's Photo Gallery
3rd Generation
I've had that problem happen to me before on the 3rd plug. Best bet, unless you're going to upgrade the spark plug wires to bigger ones, get ngk wires. I haven't had that problem scince I've had them. They're a little better then most of the other ones too.
アクション カメン 只今 さんじょう!!! ブリ ブリ ブリ。。。。。。。。。。。。
shingouki808 is offline   Reply With Quote
Old 04-17-2006, 07:37 AM   #14 (permalink)
Pabloso
project92camry's Avatar
View project92camry's Photo Gallery
maybe its ur spark plug...are they the right ones or is it messed up in anyway?
take it out.
project92camry is offline   Reply With Quote
Old 04-17-2006, 10:28 AM   #15 (permalink)
5S-FU
View Sniperdude's Photo Gallery
This just happened to me too. I used a pair of really long needle noses and just twisted it out then removed the boot remains.
Sniperdude is offline   Reply With Quote
