[Brake Light] light on? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-11-2005, 11:33 PM   #1 (permalink)
2001 Camry LE
View Nuke209's Photo Gallery
Well, inside my camry 2001 le, the little icon with the car brake lights are on but there's no problems with my lights in the back, is it a problem i can fix easily?
Nuke209 is offline   Reply With Quote
Old 03-11-2005, 11:47 PM   #2 (permalink)
View fj40supraman's Photo Gallery
Is it a ABS signal or is it for the brake light. If it's the brake light you probably have a bulb out, of which case you have to get a Toyota bulb to fix, if you don't it won't go out, done it already. If resistance isn't the same, light will remain on, even though bulb lights fine.
fj40supraman is offline   Reply With Quote
Old 03-11-2005, 11:51 PM   #3 (permalink)
2001 Camry LE
well, the lights are all still on
my friend told me it's an electrical problem
if the resistance isn't the same, how do i fix that
i'm not a car expert so try to bare with me
Old 03-12-2005, 02:36 AM   #4 (permalink)
Triple A Whore
Edmond's Avatar
View Edmond's Photo Gallery
Don't forget the 3rd brake light.
Edmond.
Edmond is offline   Reply With Quote
Old 03-12-2005, 06:24 AM   #5 (permalink)
2001 Camry LE
which is the 3rd one
Old 03-12-2005, 06:53 AM   #6 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
the one in the middle of you car, inside of it, against the back glass,
also check your brake fluid level, and to fix the resistance search around the site for led resistors and that should tell you how to fix that.
^ and leaving it that way!
Old 03-12-2005, 07:20 AM   #7 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $272321
View REN69's Photo Gallery
the little light on the dashboard that lights up when you pull up your parking brake???
no worries man.. that only means your brake fluid level is low and you gotta fill up. Check and fill both brake and ABS, it could be either one that is making it light up.
Old 03-12-2005, 07:59 AM   #8 (permalink)
View freestylez's Photo Gallery
i have the same issue i checked all my lights and even change them, they all work fine and icon is still on i dont really care anymore since the lights work just ignore it
freestylez is offline   Reply With Quote
Old 03-12-2005, 11:05 AM   #9 (permalink)
Triple A Whore
Edmond's Avatar
If everything is working fine, just take the dash off and pop the bulbs out, that's what I did. I think I damaged an ABS sensor and the ABS light was on. In Illinois, they take emissions and won't test the car is any light is on the dash, even if it doesn't have anything to do with emissions.
Edmond.
