I started up my car this morning and noticed a tapping sound coming from the right side of the engine. I cannot hear anything from the inside of the car. It idles fine does not jerk or anything. However, the smooth, quiet clicking noise I used to hear was replaced by a tapping sound. It comes from the top of the engine on the right side. I had my oil and filter changed at Toyota last week and I wonder if changing oil could cause this problem.
I checked the oil and it is full. When I push on the platic cover, towards the right side of the engine, I can feel it tap. On the left side it seems normal
What can be wrong with my engine? It has 170,000 miles. It is a Camry V6 SE 1992.
Wonder if they missed the filter, or if they stuck the wrong oil in it?
85 LE 2SE 500K km - died trying to push a semi off the road
95 LE 5SFE 530K km, 530K km changed engine, 549K km second engine died, now 554K Km running with a 98 5SFE block and head
01 XLE V6 310K km
Yeah your valves could be the one that's making the tapping noises. When I had the problem with my trooper they told me to use synethetic oil and that would cure it. Never tried it though since the problem just went away.
Anyways, tonight I decided to remove the platic cover that protects the wires and I did not have the right tools. I pushed hard on the cover and the noise went away I still could feel a vibration, stronger than usual, but the tapping noise went away. As soon as I dont put pressure on the plastic cover we can hear the tapping noise.
When was the last time you changed the timing belt? It could be time to replace the pulley and the tensioner too. Might as well change the waterpump and the serp. belt while you're doing this. Check for leaking seals too.
The timing belt is on the left side of the engine. There is not noise or vibration on that side.
On the right side, there is a stronger vibration and the tapping noise comes from there. However, if I firmly push on the plastic cover and hold it, the noise goes away. I will try to remove it. What kind of tool do I need? I want to see if the noise goes away if I remove it
I found out what's wrong with the car but I don't know how to fix it.
I removed the plastic cover and I saw three wires for the spark plugs and on the right side, we can wiggle the wire, it is not in the hole as tight as the other ones... do you know how I can fix it? That is why yesterday when I pushed on the plastic cover the noise would go away, it pushed on that wire....
I pulled on the wire and I can see the spark plug in the hole... I put back the wire on the plug but it will not go in all the way down. The other wires seems to be inserted firmly on the spark plug
It sound sto me like a noisy lifter. I have the same exact problem. It wont affect anything but the sound WILL get louder and louder over time. They sell some stuff that you can add to your oil that should cure it (Lucas Oil).
96 Camry V6 LE & 90 Eagle Talon TSI (AWD TURBO)
"Love is all you need to know and all you need to know is love is all you need to know."
