Originally Posted by ekim55121
any one know if there is a flange that will make the bolt on o2 sensor into a screw on sensor i have 2 screw sensors laying about and i want to put them to use they are oem sensors for the cam i just wanna use them
Your post doesn't make any sense.
1. Your asking if theres a flange that will convert a bolt on type sensor into a screw in type.
The answer is no.
2. Bolt on type o2 sensors already have a flange. Thats how they bolt up (2 nuts/bolts).
3. You can use a screw in type o2 sensor in place of the bolt on type. But you need a flange that has a threaded hole in the middle for the o2 sensor.
