Drive axle removal - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-14-2005, 04:25 AM   #1 (permalink)
View websterlake's Photo Gallery
Drive axle removal
I've got a 94 Camry 4cyl. Yesterday I worked at removing the passenger side CV drive axle. All went well but I was not able to remove the axle from the transaxle. From reading prevoius posts it looks like one possibility is the support bearing could be sticking in the bearing housing. I've removed the snap ring and taken the retaining bolt out. Any hints on removing this badboy? Thanks.
websterlake is offline   Reply With Quote
Old 03-14-2005, 12:12 PM   #2 (permalink)
View 500KCamry's Photo Gallery
Only two bolts hold the bearing support to the engine block. If the bearing is stuck in the support, take the support off with the axle.
85 LE 2SE 500K km - died trying to push a semi off the road
95 LE 5SFE 530K km, 530K km changed engine, 549K km second engine died, now 554K Km running with a 98 5SFE block and head
01 XLE V6 310K km
500KCamry is offline   Reply With Quote
