Correct Tire Size and ABS. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-14-2005, 05:11 PM   #1 (permalink)
View SlingXShot's Photo Gallery
Hello,
I have 1993 Camry XLE V6
I went to sears, and changed tires from 205/55/15 Goodyear to 205/65/15 Falken. Sears only recommended this size. So why were my previous tires 205/55/15? Will these bigger tires cause problems?
Also, I was turning really hard today, and my braking pedal was vibrating, is that ABS kicking in, is that normal?
Thanks!
SlingXShot is offline   Reply With Quote
Old 03-14-2005, 06:38 PM   #2 (permalink)
3rd 5-speed Camry...
87Camry5Speed's Avatar
View 87Camry5Speed's Photo Gallery
Since you're an XLE v6 I'd imagine you have ABS... if it wasn't ABS kicking in maybe you've got warped rotors (but then the whole car would shudder a little).
Steve
About the tires- the 65 series tires have larger sidewalls, which means two things for you- a little better ride but slightly number handling (steering will be a little less responsive). Since it's only a 10 mm difference, I don't think your speedo will be thrown off by much- if at all.
'08 Camry LE 5-speed. Traded for an '04 Mustang GT.
87Camry5Speed is offline   Reply With Quote
Old 03-14-2005, 07:06 PM   #3 (permalink)
Lives For The Curves
View nort0188's Photo Gallery
A 65 series tire should be the normal size... seems like you had the wrong size on there before.
If torque actually won races, wouldn't we all be driving diesels?
nort0188 is offline   Reply With Quote
Old 03-14-2005, 07:19 PM   #4 (permalink)
tC
View 95camguy's Photo Gallery
yeah my factory sized continentals are 205/65/15.^^^^^
07 tC MT
-TRD RSB
-TRD Quick Shift Kit
-TRD Exhaust
95camguy is offline   Reply With Quote
Old 03-14-2005, 08:01 PM   #5 (permalink)
There is no substitute.
EKam's Avatar
Gameroom cash: $700265
iTrader Score: 6 reviews
View EKam's Photo Gallery
Small diameter tires = odometer has more miles, faster than actual speed on speedo.
18/6/08 - Sayonara Kamuri!
EKam is offline   Reply With Quote
Old 03-14-2005, 10:27 PM   #6 (permalink)
Auto-Cross Addict
SmokingTires's Avatar
View SmokingTires's Photo Gallery
Yup. Stock sidewall is 65. That's what my Goodyears are.
'88 Toyota MR2 N/A - Sold
'99 Miata Sport - Sold
'85 Corolla GT-S - Sold
'02 MR2 Spyder - C-Stock car
SmokingTires is offline   Reply With Quote
