Lowering springs or sports springs....cut down threadwear on tires? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-14-2005, 09:22 PM   #1 (permalink)
Eaten iVtecs before!
View coolchu001's Photo Gallery
Do having lowering springs or some sort of sports springs on a car lower the thread wear of the tires?
coolchu001 is offline   Reply With Quote
Old 03-14-2005, 09:24 PM   #2 (permalink)
97camryman's Avatar
View 97camryman's Photo Gallery
Only if you never align the car after lowering it. After lowering the alignment will suck and the camber will be off meaning the inside edges of the tires wear faster than the outsides.
97camryman is offline   Reply With Quote
Old 03-14-2005, 09:31 PM   #3 (permalink)
so its best to get the car lowered.....and then get a full alignment?
Old 03-14-2005, 10:03 PM   #4 (permalink)
There is no substitute.
EKam's Avatar
Gameroom cash: $700265
iTrader Score: 6 reviews
View EKam's Photo Gallery
If any suspension components get removed then reassembled, you'll need an alignment.
18/6/08 - Sayonara Kamuri!
EKam is offline   Reply With Quote
Old 03-14-2005, 10:05 PM   #5 (permalink)
Auto-Cross Addict
SmokingTires's Avatar
View SmokingTires's Photo Gallery
Always best to do so. And while your at it, if your going for performance, have them add some negative camber. It will give you an edge in those turns
'88 Toyota MR2 N/A - Sold
'99 Miata Sport - Sold
'85 Corolla GT-S - Sold
'02 MR2 Spyder - C-Stock car
SmokingTires is offline   Reply With Quote
Old 03-15-2005, 12:46 AM   #6 (permalink)
97camryman's Avatar
Eh I have found that I favor 0 degrees camber best over any positive or negative camber. Tein S springs, Tokico struts, Konig rims, and Kumho 712 supra 225/40/18 tires rock the twisties hardcore!
Old 03-15-2005, 03:16 AM   #7 (permalink)
spin turbo hammy... SPIN!
Hamsterman's Avatar
iTrader Score: 30 reviews
View Hamsterman's Photo Gallery
quick suggestion... don't get the allignment done RIGHT after your new springs/struts... need to wait a couple weeks to let the springs settle so that you don't need to adjust again after they go down another finger or half finger.... i waited a month or so on mine, i was lazy
Lick first... ask questions later
Hamsterman is offline   Reply With Quote
Old 03-15-2005, 08:58 AM   #8 (permalink)
The Other White Meat
terrastrife's Avatar
Originally Posted by SmokingTiresV6
Always best to do so. And while your at it, if your going for performance, have them add some positive camber. It will give you an edge in those turns
you mean negative camber. put 1.5-2 degrees of negative camber up front to improve HARD cornering grip, but with uneven tyre wear. i stress HARD cornering as camber does nothing if you arent pushing hard. 0 or even 0.2 degrees of positive camber to keep even tyrewear.
terrastrife is offline   Reply With Quote
Old 03-15-2005, 08:25 PM   #9 (permalink)
REAPER STRAIN's Avatar
View REAPER STRAIN's Photo Gallery
after lowering mine with the Springtechs mine was 1 degree off but I will wait for it to settle before I align it. I have been eyeing the eibach camber kit for the job. Once these bad boyz settle themselves out I will get 2 pair and have my tires aligned. For now, the back "seems" lower than the front. But then again I measure with me eye instead my finger.
REAPER STRAIN is offline   Reply With Quote
Old 03-15-2005, 09:06 PM   #10 (permalink)
no need for a camber kit.. the stock suspension can get around 5 degrees of camber adjustment easy.
Old 03-15-2005, 09:18 PM   #11 (permalink)
Toysrme's Avatar
View Toysrme's Photo Gallery
Cool
It's not really bad... You should always have it realigned anyways. The good news is that Toyotas are notorious for their ability to hit shit and stay in alignment. They tend to stay in alignment almost indefinately once they're put there.
Like terrastrife said. Camber and other re-alignment kits are not needed. They're not even made hah!
AIM/Yahoo Toysrme257th
Now with Turbo!
Old 03-15-2005, 09:43 PM   #12 (permalink)
TN's Financial Expert
BullMarket's Avatar
View BullMarket's Photo Gallery
I am pretty sure they are made...98%. I am most familiar with eibach's kit. But no you shouldn't need a kit if under 2" drop.
BULLMKT
SFTIEREEL
BullMarket is offline   Reply With Quote
Old 03-15-2005, 09:47 PM   #13 (permalink)
Camry's are so F'ing sick
best camry ever's Avatar
View best camry ever's Photo Gallery
Not directly but you'll (hopefully) be taking turns harder which will result in reduced tread wear
best camry ever is offline   Reply With Quote
Old 03-16-2005, 05:01 AM   #14 (permalink)
I have a printout of what the factory spec is supposed to be (according to Firestone) and the Camber is supposed to be + or - 1 degree (or .98 degrees if I am not mistaken). The technician told me that the factory bolts would not allow for much (if any) camber adjustment. Thats why I have been eyeing a camber kit. It allows adjustments up to - or + 2 degrees. Is what the mechanic said true?
Old 03-16-2005, 09:09 PM   #15 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $308075
The Camry suspesion does not change camber significantly when lowered. You will NOT need a camber kit... You should be running on the 'high' side (more negative camber) of the factory settings anyway (more camber is good... I run almost 2* all around on my WRX and 1-1.5* on my Camry).
-Charlie
