What are the gauge cluster bulbs sizes by the P-R-N-D-2-L
What are the gauge cluster bulbs sizes by the P-R-N-D-2-L gear shift indicator? what kind of bulbs are that? (how many Watt etc...) and is there only one bulb, because the hole task is not shining and the "D" is alsow not shining!
on the light on the dash is a 74 i think, someone correct me if wrong. you can swap out the light from the '2' or 'L' the bulb on the center console is 194
The shifter aseembly uses ONE 194-sized wedge bulb.
The gauge assembly I believe is also a single 194-sized bulb, but you'd have to take off the entire thing to replace it... IMO, not really worth it, just look down real quick if you dont' know what gear you're in...
it is one of those tiny expensive screw in jobs. You may already have a ready spare in there with holes that never light up. I have one that says MANU that will never come into use but had a bulb there. Only Toy dealer part. $2 - $2.50 ea. Be sure to check before you screw your whole dash back together, I blew other bulbs as I replaced them and cannot count how many times I disassembled my dash.
what's the bulb size in the "map light" (right by the rear view mirror)? sylvania says 194 but thats not whats in there now and has shitty light output (very dull and dim)
thanks
-Matt
When in doubt, use the search function (link)...no one is spoon fed...
