Really noobie question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-17-2005, 05:28 PM   #1 (permalink)
Yota4Life
View just2asian's Photo Gallery
3rd Generation Really noobie question
alright everyone, this is a really noobie question and I'll probably get flamed for this one. Just bought a autometer volt gauge to keep an eye on my batteries juice. I just run a power wire and a ground to the battery, and then tap another wire into the headlights so that it comes on with themright? Thanks.
-Peace from the Fareast
http://www.cardomain.com/id/donzilla2004
just2asian is offline   Reply With Quote
Old 03-17-2005, 05:36 PM   #2 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Power: Ignition (switched +12V)
Ground: Self explanatory
Illumination: Tap into the parking light wire. Its a green wire on one of the plugs behind the gauge cluster.
Hell you can grab all 3 of those wires from the wiring harness going to the stereo/head unit.
If you hook it up like you said, the gauge will stay on all the time.
"Skoolin' the unlearned!"
Old 03-17-2005, 05:38 PM   #3 (permalink)
VeeZed
JetspeedCamry's Avatar
View JetspeedCamry's Photo Gallery
Depends on the guage really.
If you have it directly connected to your battery..itll be on all the time.
If the guage has a remote wire, that should be connected to the ignition.
The illumination should be connected to your vehicle parking switch.
If the guage doesnt have a remote wire, connecting the power wire to you accessory circuit is probobly a bad idea as that circuit is under a different load.
To be real fussy, i'd use a relay that is triggered by the ignition +12V which switches the main power from the battery.
1988 Toyota Camry 2VZ-FE E153
1972 Ford Mustang Sprint "F" 351C-2V 4SPD
1973 Ford Mustang Mach 1 "Q" 383C-4V FMX
JetspeedCamry is offline   Reply With Quote
Old 03-17-2005, 05:55 PM   #4 (permalink)
Grenaded piston
88 LE's Avatar
^ A gauge doesn't draw a lot of current. Its just a display with a few leds.
Using a relay is unnecessary and just creates extra wiring. I could see if you were powering a bunch of stuff off a single low current source.
Besides if hes asking how to hookup a few wires on a gauge. You think he knows how to properly hookup a relay?
Theres no need to make it more complicated then it is. Its not rocket science.
Old 03-17-2005, 06:25 PM   #5 (permalink)
97camryman's Avatar
View 97camryman's Photo Gallery
I connected mine in parallel with the cigarette lighter that is only on with the ignition. Positive to positive ground to ground.
97camryman is offline   Reply With Quote
Old 03-17-2005, 06:50 PM   #6 (permalink)
VeeZed
Sorry.
Old 03-17-2005, 07:11 PM   #7 (permalink)
Yota4Life
thanx a bunch guys
Old 03-21-2005, 10:58 PM   #8 (permalink)
How Ya Like Me Now?
View Anshu's Photo Gallery
for the illumination, would it be best to tap into the dimmer wire for the oem sterero(i have an aftermarket and would think that it should be unused)
98 V6 XLE
Dell 5100|SB Extigy|PPI DCX 730|NEXT 4.00|Monitor 2.70|ED Nine.1|LPG 26||Alpine Type R|ED 11ov2's and some other junk
Anshu is offline   Reply With Quote
