stock swaybar diameter - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-18-2005, 05:47 PM   #1 (permalink)
40x40 pixels is crap !
Velox_camry's Avatar
View Velox_camry's Photo Gallery
im about to order energy suspension bushings for my stock front swaybar on my gen 4 cam. but i see 2 sizes... 18mm and 19mm. which one am i supposed to order ? heres a link...http://nipponpower.com/suspension/bu...es_toyota.html
"Guardrails...those things that separate the men from the boys."-Fumiaki Komatsu
Velox_camry is offline   Reply With Quote
Old 03-18-2005, 07:22 PM   #2 (permalink)
The Other White Meat
terrastrife's Avatar
im taking a random guess that 18mm is i4 and 19mm is v6?
terrastrife is offline   Reply With Quote
Old 03-19-2005, 06:07 AM   #3 (permalink)
yeah im not too sure i was either thinking that or one if for aftermarket swaybars...
Old 03-19-2005, 02:03 PM   #4 (permalink)
Toysrme's Avatar
View Toysrme's Photo Gallery
Cool
The whiteline is like 20mm on a gen3. I forget offhand, but remember it being like 16-17, or 17-18 at most.
The whiteline dwarfs the stock one.
AIM/Yahoo Toysrme257th
Now with Turbo!
Old 03-21-2005, 01:55 PM   #5 (permalink)
View TRD_Rob's Photo Gallery
4th Generation Re: Energy Suspension for Stock Bar
Hi:
I changed the stock Front and Rear sway bar bushings for my 1998 Camry. My car had 17mm in the Front and 16 mm Back. I bought mine from:
http://www.suspension.com/toyota.htm
If you call them, they will ask the size of the bar. They are very knowledgable and parts fit perfect. Here are the part number for a 1998 Camry:
Front- 17mm- 9.5121G
Rear- 16mm- 8.5120G
I did notice a difference after installation. Greasable bushing are not available.
Hope this helps
TRD_Rob
PS: After installation, they do squeak for a couple of weeks. Once broken in, they are quiet.
1998 TRD Camry
Injen Air Intake with HKS Filter
HKS Plugs with Vitek Wires
Dynomax Exhaust System
Evans NPG+ Waterless Coolant
TRD_Rob is offline   Reply With Quote
