144k too late for synthetic? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-18-2005, 08:20 PM   #1 (permalink)
View Calvin327's Photo Gallery
Is it too late to use synthetic oil now? 144k now, motor and tranny still good and running strong. I was hoping to run full synthetic mobil 10W30. Any advice is gladly appreciated. I got a 94 5sfe.
Thanks
Calvin327 is offline   Reply With Quote
Old 03-18-2005, 08:33 PM   #2 (permalink)
Triple A Whore
Edmond's Avatar
View Edmond's Photo Gallery
I don't know if it's too late but if everything is fine right now, why switch?
Edmond.
Edmond is offline   Reply With Quote
Old 03-18-2005, 08:35 PM   #3 (permalink)
Toysrme's Avatar
View Toysrme's Photo Gallery
It's never too late. Synthetics are the life-blood. Use them. Should have been done 144,000 miles ago.
Please direct all future oil questions to the Bob is the oil guy website.
AIM/Yahoo Toysrme257th
Now with Turbo!
Old 03-18-2005, 09:02 PM   #4 (permalink)
I get angry when Im sober
Stealth's Avatar
View Stealth's Photo Gallery
Oh there are times its too late and I wouldn't risk it. Your car has been running on dino oil for the duration of it's life and it still runs fine, why switch? Regular oil may have created some seals that may dissolve if you use synthetic and cause leaks.
1995 Silverleaf Metallic Camry LE Automatic beater
1987 Buick Grand National
Stealth is offline   Reply With Quote
Old 03-18-2005, 09:05 PM   #5 (permalink)
The Other White Meat
terrastrife's Avatar
and then youll see that you got leaks and replace htem b4 they blow out!
terrastrife is offline   Reply With Quote
Old 03-18-2005, 09:58 PM   #6 (permalink)
Zzzz
CrawlingEye's Avatar
View CrawlingEye's Photo Gallery
yup, and your motor will run all the stronger.
The *worse* oil I'll put in my car is Mobil synthetic blend.
I like amsoil but sometimes it's just too expensive. ($50 for an oilchange).
The whole logic of not changing so you save shit seals is just retarded. Sorry...
-mark
'93 Camry LE (5S-FE)
CrawlingEye is offline   Reply With Quote
Old 03-18-2005, 10:20 PM   #7 (permalink)
i use catrol gtx magnatec.. which.. is mineral based i think.. i have to change quite often though.. it gets black pretty fast.
Old 03-18-2005, 10:25 PM   #8 (permalink)
View bowlofturtle's Photo Gallery
i use cheap-o walmart oil. 87k miles. no issues with oil. But then again i change oil often 2,700miles but 2000 of them are highway.
96 Camry Le I-4
bowlofturtle is offline   Reply With Quote
Old 03-19-2005, 12:38 AM   #9 (permalink)
MadDawg's Avatar
View MadDawg's Photo Gallery
nope... it just means you gotta change it between 3-4k anyway... my camry had like 136k on it when i put mobil syntec in it.... although the valve cover leaks, its 141k now and its like pretty dark looking oil... too bad the dealer ship was booked for 2 weeks straight for a damn oil change
MadDawg is offline   Reply With Quote
Old 03-19-2005, 10:29 PM   #10 (permalink)
View Kooterskkar's Photo Gallery
Just replace all the oil seals and you can run synthetic with no worries. (its much better for old engines just not for old seals)
Also, AMSOIL has a drain interval of 25k miles, or one year. I had some test results I found online from someone who used that stuff and had the oil tested after 6 months. It was just fine. Just gotta change the filter every 6 months or so. Plus AMSOIL makes a bypass filter that will filter out particles as small as .1 micron. So you might spend 75 bucks on a case of oil and a filter, but you get 12 quarts, which makes 2 oil changes, and then some (if your car only takes 5 quarts). Or 3 changes if your car only needs 4 quarts at a time. Changing the oil 4 times a year with regular oil at about 20 bucks per change is 80 bucks. You only gotta do it once a year under normal driving with the AMSOIL. So it almost costs less to use synthetic. (as long as its not leakin everywhere)
Kooterskkar is offline   Reply With Quote
Old 03-19-2005, 10:47 PM   #11 (permalink)
93 240sx SR Hatch
DAMON's Avatar
iTrader Score: 36 reviews
View DAMON's Photo Gallery
i switched to mobil 1 synthetic in my 94 camry about 9000 miles ago and havent had a problem yet with leakage (fingers crossed)
94 Camry (Beater) 99 Solara (Totaled) 93 240SX (Current)
DAMON is offline   Reply With Quote
Old 03-19-2005, 11:19 PM   #12 (permalink)
Whether or not it will leak depends on how often the oil was changed before. If the engine is clean you wont have any problems, but if it had a bunch of gunk and sludge built up around the seals (from not being changed often enough) then switching to synthetic will clean out all that gunk and open up those potential leaks. If you dont have any leaks yet, after 9000 miles, its probably not gonna happen any time soon, if at all.
Old 03-20-2005, 04:35 AM   #13 (permalink)
Thanks guys. I appreciate all the comments. I don't believe my seals are bad, I've been taken very good care of the car ever since I got it. I'll be using mobil 1 fully synthetic from my next oil change on.
Calvin
Old 03-20-2005, 01:39 PM   #14 (permalink)
Its freakin hot here...
View ArmyofOne's Photo Gallery
I may very sell switch on my next oil change at 145,000 miles. will have a compression test doen first though.
I just had every extenal seal on my motor replaced except for the rear main seal, so i should be in good shape externally. internally i may be ok too, but thats what the compression test results should yeild.
2006 Honda Civic EX in Galaxy Gray Metallic Pearl-WR Blue Brake Calipers, Ipod Integration, Debadged, K&N Drop-In, Mobil 1 Synthetic oil, Bridgestone Turanza 215-55-R16 Shoes, RedStuff Ceramic Brake Pads, Tint w/3m SolarGaurd film: 5% rear, 15% front, 30% moonroof
ArmyofOne is offline   Reply With Quote
Old 03-20-2005, 06:41 PM   #15 (permalink)
View warlock's Photo Gallery
i'm running royal perpal 10/3 now and i have 201,000+. ive been run sentec sence 90,000.
94 Scepter 1MZ-FE
< TN Type [R]ice Club>RICERS UNITE!! Join Type R..latest faction of TN!!
.....http://www.toyotanation.com/forum/sh...d.php?t=105457
warlock is offline   Reply With Quote
