Cruise Control NOT working!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-19-2005, 01:27 AM   #1 (permalink)
View CX889's Photo Gallery
4th Generation Cruise Control NOT working!!
My car is 97' Camry V6 XLE 1MZFE. I donno why the cruise control is not working. Even in 100km/h is still not working. How can I check whether anything has gone wrong. If it's busted, I am not gonna spend money fixing it anyway but I wanna know the problem. Thanks! Pictures will be even better.
CX889 is offline   Reply With Quote
Old 03-19-2005, 03:40 AM   #2 (permalink)
View karazy's Photo Gallery
Check the fuse, make sure the cables are good and verify that the brake and clutch switches are ok.
karazy is offline   Reply With Quote
Old 03-19-2005, 03:55 AM   #3 (permalink)
I am just a noob! I can check the manual on the location of the cruise control fuse but can you show me where are the rest? Thanks!
Old 03-19-2005, 04:18 AM   #4 (permalink)
If the brake lights work and the clutch in to start works, the switches are ok. The cables and linkage are in a big black box beside the battery.
Old 03-19-2005, 12:51 PM   #5 (permalink)
How about this, I will post a picture so you can show me the problem. Picture worths 1000 words
Old 03-19-2005, 11:11 PM   #6 (permalink)
4th Generation
This the the fuse relay center.
Reference
Cruise Control
Hope these pics help
Old 03-20-2005, 09:15 AM   #7 (permalink)
The only ref I have is a gen3 I4, but the fuses for the CC are on the under dash panel. ECU-IG & stop For the 2 switches. As for the CC unit, it looks pretty clean, just check for cable freedom. After that, it becomes a wire chasing game and you'll need a manual for that.
Old 03-20-2005, 09:56 AM   #8 (permalink)
Toyota manual you mean?
Old 03-20-2005, 03:09 PM   #9 (permalink)
Yeah, Haynes and Chilton have wiring diagrams. If it's not a fuse or switch, it could be the ECU, bad ground, faulty control sw/, or just a loose wire. You can't check it, if you don't know where it is. You can try the obvious ones and you may get lucky.
