try going to autozone and picking up some eagle one chrome cleaner. it's petroleum based and actually is intended to 'eat away' a small (dirty) portion of chrome. you just rub the cotton-like piece on and wait until a milky film develops and just wipe it off (I usually wipe then take a wet paper towel and clean it off with that).
I used a cutting compound and clotch..rubbed em down and then used a non scratch steel wool to finish it off..oh and then some polish. Looked brand new....
__________________ 1988 Toyota Camry 2VZ-FE E153
1972 Ford Mustang Sprint "F" 351C-2V 4SPD
1973 Ford Mustang Mach 1 "Q" 383C-4V FMX
Im not trying to jack the thread, just a quick question...
My headlights were very yellow on my 94, beyond cleaning, so i bought new ones. The passenger side light was for some reason more yellow.
Its been a good 4 months and the passenger side headlight is already visibly yellow, wheras the drivers side looks like new. Is there a seal or weatherstrip that I should replace? How do I know if the yellow film is on the inside or outside? I need to try the chrome polish trick.
Can I remove them and soak them in anything to get them clear again?
There was a DIY thread somewhere on here that showed step by step directions on how to remove the headlight lens. If u do a search, I'm sure it'll pop up.
Its not what u drive, its how u drive it!
THnks for the suggestions fellas.. I'll try and Clean the outside first and see if that makes a difference and if that doesn't workI'll look for the DIY thread and see about taking the whole thing apart..
you can also use toothpaste! and meguiar's makes a plastic cleaner that I have used on my lights and has worked well
the chrome cleaner is likely better than toothpaste. toothpaste is more for polishing (very light abrasive), where-as the chrome cleaner is intended to clean and is a bit stronger.
