Driveshaft realisation... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-21-2005, 04:39 PM   #1 (permalink)
VeeZed
JetspeedCamry's Avatar
View JetspeedCamry's Photo Gallery
Part of my manual conversion is going to be using Gen 3 3VZ inner axles with my Gen 2 outer axles. The reason was so as to keep my rims and brakes etc (as Gen 2 uses 5x100 pattern). I have realised that my rims are multifit...that is..have 5x100 & 5x114 mounting ability!
The question is...if i got FULL driveshaft...will my front brakes work with them? or do i have to get all of the related brake hardware and modify it to fit?.
Thanks.
1988 Toyota Camry 2VZ-FE E153
1972 Ford Mustang Sprint "F" 351C-2V 4SPD
1973 Ford Mustang Mach 1 "Q" 383C-4V FMX
JetspeedCamry is offline   Reply With Quote
Old 03-21-2005, 05:21 PM   #2 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
The driveshaft (cv axle) is seperate from the hub / steering knuckle. Although the axle goes into the backside of it.
To change the bolt pattern you need a adapter or new hub.
If you get full axles (for a 3VZ) you might have to change the steering knuckle, brakes, etc.. This is if the axle doesn't mate with your existing steering knuckle.
I would choose the easier route and use hybrid axles (3VZ inner w/2VZ outer).
"Skoolin' the unlearned!"
Old 03-21-2005, 06:01 PM   #3 (permalink)
VeeZed
^ Ok thanks 88LE.
Will do.
