Trouble with backup lights and dash shifter lights. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-21-2005, 09:24 PM   #1 (permalink)
View camry1993's Photo Gallery
I have a 93 automatic Camry. Some of the dash shifter lights work part of the time. D never does and reverse didn't untill I push it up just right and hold it. The reverse lights work when the dash R lights. I took the shifter cover plate off and I see a square shaped "switch or module" with four little phillips screws. Is this the shifter switch that is causing the problem? Is it hard to change out? I could probably get one at a junk yard pretty cheep. And does the side of the console come off easily? I'd like to fix this problem myself. Thanks for the help.
camry1993 is offline   Reply With Quote
