Replacing intake, time to do some cleaning - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-21-2005, 10:44 PM   #1 (permalink)
3VZ-FE Camry
View sanengo's Photo Gallery
3rd Generation Replacing intake, time to do some cleaning
I am replacing my stock CAI with a custom SRI (hopefully will become a CAI one day) and I would like to know what I could do in terms of cleaning/checking various valves/pipes/sensors when I replace the intake.
So far I read the forums and thought it would be a good idea to take a carb/throttlebody cleaner to the throttlebody and toothbrush all the dirt and grime out. Any tips?
Also, I've read that cleaning the PCV and IAC are highly recommended. I have a Haynes Repair Manual for my car and have located all these sensors, but how should I clean or check them?
Finally, how do I take out the MAF sensor from my existing intake and fit it on my SRI? From what I see, the MAF sensor is incased in a metal housing above my air filter box with a connector connected to it.
Thanks! I greatly appreciate all the help you guys are giving! I've read through quite a bit of posts and haven't found clear definitive answers/procedures to these problems.
sanengo is offline   Reply With Quote
Old 03-22-2005, 03:24 AM   #2 (permalink)
The Other White Meat
terrastrife's Avatar
you cant really clean anythign without taking off your manifold.... cleaning the outwer side of teh tb isnt going to help...
open your airbox.. tehres 4 screws.
get out and look at your car, you couldve answred these in a few minutes
terrastrife is offline   Reply With Quote
Old 03-22-2005, 09:41 PM   #3 (permalink)
3VZ-FE Camry
Ok I was talking to toyrsme the other day, (unban him plz ) and he told me my car had an AFM! not a MAF! that means I'm stuck with an extension where that sensor is. My intake came today, and I measured just enough room to sqeeze in the AFM, but not a milimeter more. I might even have to relocate that slender fuse box, but that's not a problem.
I'll have pics of the install soon, so hopefully any newcomers will have some visuals on how intakes may fit on the old 3vz engine. (If I'm successful)
