Originally Posted by fe519
im pretty sure its your iav thats busted... really sounds like it
I want to be almost 100% sure before I spend $200 for the IAC valve so that's why I'm performing this test. The car starts fine 3 out of 5 times. Seems to do better when it has been driven for a while. Seems to do worse when it's a cold start. So I'm open to other reasons why my car stalls only sometimes right after I start it up.
Originally Posted by mobes
What car is this on? If it's a 97 or 02 as your name implies, you have an OBDII system and need to use a code reader.
Sorry for being unclear. It's a 97 LE 5SFE with only 52k miles. There is no CEL so I thought maybe there's no code to read. Haynes said the CEL would stay on if the problem persisted after 2 drive cycles. It would go away after 3 drive cycles if the problem is no longer there.
Edit: Or are you referring to a specific IAC test procedure?
Yes I am referring to a specific test procedure outlined in the Haynes manual. This is the 1st out of 3 tests to see if the IAC is working properly.
