Crappy Acceleration - yes I searched - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-26-2005, 10:01 PM   #1 (permalink)
Lex Zues!
RedPhoenix's Avatar
iTrader Score: 12 reviews
View RedPhoenix's Photo Gallery
Recently, or maybe its always been like this, my accelration is getting worse and worse. Only thing I have is a ram air intake. Now I searched came up with only one thing that I can see, its my throttle body, might be dirty. I plan on looking at it this weekend, but other than what could it be?
Sold ^
Originally Posted by dysk8forlife
supercharger whine>girlfriend whine
RedPhoenix is offline   Reply With Quote
Old 03-27-2005, 10:06 AM   #2 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
check the air hose inbetween the throttle body and mass air for cracks
Old 03-27-2005, 11:00 AM   #3 (permalink)
Lex Zues!
RedPhoenix's Avatar
That hose looks okay, looks worn but still intact. Ill replace it with some hose I have left over from my intake.
I found this, no idea what it is but its broken.
Sold ^
Old 03-27-2005, 11:28 AM   #4 (permalink)
3VZ-FE Camry
View sanengo's Photo Gallery
I'm not too familiar with 4 cylinder engine, but I think that is your BVSV. Definitely get that fixed. It is connected to the intake and probably allowing access air into your TB. Typically it's used to control emissions.
sanengo is offline   Reply With Quote
Old 03-27-2005, 03:55 PM   #5 (permalink)
Lex Zues!
RedPhoenix's Avatar
will do... anything else?
Sold ^
Old 03-27-2005, 04:03 PM   #6 (permalink)
View starfuryz's Photo Gallery
Its a bimetal somethign or other. Parts stores will have it listed as something else, just have them keep brining parts out. Mine was broken as well, will set u back about 60 bucks. It goes from either the tb or egr to the charcoal canister. It will help your acceleration, it did mine. Mine was broken, and the car was slow as a special olympics chess tournament.
But yea, definatly fix that.
starfuryz is offline   Reply With Quote
Old 03-27-2005, 04:12 PM   #7 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
its a vacuum control valve, depending on the way its set up, it eather opens cold or hot, where do the hoses go?
Old 03-27-2005, 04:36 PM   #8 (permalink)
Killa Clean Gen 3
View Gen3cruiser's Photo Gallery
It is the bimetal valve, a toyota only part, and pricey. Retails for $70+, but you should be able to haggle it doen to $50.
222,000 miles, dead, car wreck. RIP
Gen3cruiser is offline   Reply With Quote
Old 03-27-2005, 04:41 PM   #9 (permalink)
Lex Zues!
RedPhoenix's Avatar
and the bimental valve will mess up my accelration, correct? Car works fine without it, just dont need to lay down some cash for my original problem and not have it work, ya know?
Sold ^
Old 03-27-2005, 04:48 PM   #10 (permalink)
Killa Clean Gen 3
No, bimetal valve is a temperature controlled valve to help control idle, it acts as a bypass when engine is cold, and closes as the engine warms.
All this will do is make you car run fast idle or ruff idle depending on temperature, but I would still replace it.
A junk yard should be able to hook you up if you don't want to spend big bucks at toyota.
Old 03-27-2005, 06:59 PM   #11 (permalink)
Its freakin hot here...
View ArmyofOne's Photo Gallery
mine is gone on my gen II v6, and i noticed no difference in performance. i have 6 hoses that are supposed to be connected to mine, and i havent got a single one connected.
its a Vacuum Switching Valve.
2006 Honda Civic EX in Galaxy Gray Metallic Pearl-WR Blue Brake Calipers, Ipod Integration, Debadged, K&N Drop-In, Mobil 1 Synthetic oil, Bridgestone Turanza 215-55-R16 Shoes, RedStuff Ceramic Brake Pads, Tint w/3m SolarGaurd film: 5% rear, 15% front, 30% moonroof
ArmyofOne is offline   Reply With Quote
Old 03-27-2005, 07:22 PM   #12 (permalink)
Lex Zues!
RedPhoenix's Avatar
alright. ill junkyard it when I go for my new trunk latch.
So any ideas why my acceleration is lacking? I used to feel the car pull me, now all I here is the intake (loud...) but no power to show, might be all phycological, but I dont know.
Sold ^
Old 03-28-2005, 03:57 PM   #13 (permalink)
3VZ-FE Camry
Seafoam time? Try reseting your EFI fuse and recalibrating the transmission to your needs.
Old 03-28-2005, 04:55 PM   #14 (permalink)
View alxch1n16's Photo Gallery
sorry to hijack the thread, how does one go about resetting the efi fuse and recalibrating the transmission for a gen 3?
alxch1n16 is offline   Reply With Quote
Old 03-28-2005, 07:53 PM   #15 (permalink)
Lex Zues!
RedPhoenix's Avatar
also curious ^^
Sold ^
