Tower Strut Bar Install - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-28-2005, 12:56 AM   #1 (permalink)
Gold Power!
MoldySpore's Avatar
View MoldySpore's Photo Gallery
4th Generation Tower Strut Bar Install
Quick question. When you install the upper tower strut bar, do you have to get an alignment afterwards? also, when you take the 3 bolts out of the top of the tower, will that dislodge the strut? should it be on jacks/lift when this is done?
thanks in advance all
---MoldySpore
RIP: '97 Camry V6 XLE
New Car: 2011 Camry SE V6
Current Upgrades: TRD Exhaust + Springs
MoldySpore is offline   Reply With Quote
Old 03-28-2005, 01:07 AM   #2 (permalink)
View T3vzGfeF's Photo Gallery
well i installed my tower strut bar after i got an alighment...and and no it will not dislodge the strut as long as your car is in the ground...so dont jack it or lift it just leave it on the ground...the 3 bolts on top doesnt hold the springs its the nut in the middle that removes the spring...and so just take the 3 bolts out and install your tower strut bar...
post up some pics...
T3vzGfeF is offline   Reply With Quote
Old 03-28-2005, 08:50 AM   #3 (permalink)
Motorcyle Tech
Racer_Rodney's Avatar
View Racer_Rodney's Photo Gallery
^^^^yeah like he said.....lol
maybe this will help
take it off one side at a time and put the ends on, then put the bar in the middle and adjust it. IF you over tighten it you will need an alignment, just make it a little tight and lock it in place. You should notice the differance most during high speed cornering
good luck
CarDomain pics-->http://members.cardomain.com/racer_rodney
My WebSite------>http://rcarman.home.mchsi.com/
Racer_Rodney is offline   Reply With Quote
Old 03-28-2005, 11:10 AM   #4 (permalink)
Gold Power!
MoldySpore's Avatar
Excellent. I noticed you have what looks like the SPW strut bar. I got a Toucan. Anyone had any experience with them?
I was going to get a SPW but it seemed like everywhere I went they had too many weird end. some were half-moons w/ only 2 bolts. others were like yours with 3. seemed kinda shady.
Oh, and ill definatly post some pics. I'll do a write up for installation like i did for my intake. Every mod I do im gonna write up a guide for installing. There is such a lack of installation guides. I figure it'll help noobs out. Just gotta get the mods to sticky them
---MoldySpore
Old 03-28-2005, 12:42 PM   #5 (permalink)
Motorcyle Tech
yeah its the SPW the other ones pictured (2 bolt) are just the picture, not the actual one for our cars.
Old 11-21-2005, 07:41 PM   #6 (permalink)
FLIP'N THE G-5 WHIP
RICO8458's Avatar
View RICO8458's Photo Gallery
good luck
Hi, i noticed you have a 3 piece strut tower bar. when it came time to tighten it in place did you tighten it pulling inward or outward? pressing outward or pulling inward on the force? when turning the middle bar?
Got the 50 on my jock cause my G-5 is so Hot...
2005=5.5 2AZ-FE, 2.4L DOHC 16-Value VVT-i, 4CYL, 160hp
RICO8458 is offline   Reply With Quote
Old 11-21-2005, 09:22 PM   #7 (permalink)
Where are we going today?
skewe's Avatar
View skewe's Photo Gallery
Does the SPW really work? Was thinking of getting it off ebay but not sure bout it..
skewe is offline   Reply With Quote
Old 11-21-2005, 10:13 PM   #8 (permalink)
Motorcyle Tech
Yeah I have had gppd results from the SPW and actually used the Whiteline lower brace to help stiffen it up as well.
as far as the tightening I put it on and had it push out I guess a little. but what you are really looking for is to install it and have it hold everything where it is not really push or pull.
also when you have it on get your alignment checked. if it is off the brace is over tightened.
good luck guys.
Old 11-21-2005, 10:27 PM   #9 (permalink)
skewe's Avatar
good luck guys.
did you have to put the bar the opposite way around cos i know somebody installed it and it hit the intake manifold whenever you accelrate.
there is one dude on TN who shaved the bar so that it will fit.
Old 11-22-2005, 12:15 AM   #10 (permalink)
touringcamry's Avatar
Gameroom cash: $550825
My photos...hope they help...
Click on them to enlarge.
The nuts will stick up like this after the install. Not much you can do about it really. Torque to 59 pound-feet.
Remove the nuts on top of the strut mounts. Then put the bar on. Tighten down the nuts for the strut mount. Then tighten down the nuts between the center section and the feet.
The nuts on top of the strut mount are 14mm, and an impact comes in handy here if you have access to one. If you are doing this, my suggestion is you get a long handle ratchet, ie a 1/2 drive or similar. An impact will probably over tighten them. Most 3/8" drive ones don't have sufficient leverage for 59 lb-ft of torque...I can only get 25-30lbs with an 8" long 3/8" drive ratchet handle.
2007 Camry 2.4L 5M
Old 11-22-2005, 01:05 AM   #11 (permalink)
Motorcyle Tech
nope fit perfect the regular way, I got mine off ebay too
if iit hit the manifold on acceleration they have a broken motor mount and the motor is shifting too much
Old 11-22-2005, 08:04 AM   #12 (permalink)
skewe's Avatar
i know this dude grind the strut bar to have it fit
http://www.toyotanation.com/forum/t89470.html
more pics
http://www.cardomain.com/ride/587772
Old 11-22-2005, 09:47 PM   #13 (permalink)
Motorcyle Tech
more pics
Big Body had to shave it down????
wow, I don't know, Maybe we installed it differantly??
