Power Steering Fluid - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-30-2005, 10:55 PM   #1 (permalink)
View localmotion's Photo Gallery
I have a 1996 Toyota Camry and i put prestone power steering fluid in it today. I did not realize that it needed some other type of fluid. On the containter, it does not say anything but it being "comaptable" with most foreign cars. will it matter if its not the fluid the factory recommended?
Thanks
matt
localmotion is offline   Reply With Quote
Old 03-30-2005, 11:54 PM   #2 (permalink)
View Boostaholic's Photo Gallery
ATF Dexron III
Boostaholic is offline   Reply With Quote
Old 03-31-2005, 01:22 AM   #3 (permalink)
97camryman's Avatar
View 97camryman's Photo Gallery
Thats really bad!!! You totally screwed it up if the fluid is different from factory, the seals will swell an burst eventully. Save up for new parts and dont do that again!
J/K you should be fine. In the future try and use recommended fluid.
97camryman is offline   Reply With Quote
Old 03-31-2005, 11:38 AM   #4 (permalink)
tC
View 95camguy's Photo Gallery
Originally Posted by Boostaholic
ATF Dexron III
i believe its dextron II. however, i wonder if it matters much
07 tC MT
-TRD RSB
-TRD Quick Shift Kit
-TRD Exhaust
95camguy is offline   Reply With Quote
Old 03-31-2005, 03:01 PM   #5 (permalink)
cani just flush it out and change the fluid?
matt
Old 03-31-2005, 03:24 PM   #6 (permalink)
Where are we going today?
skewe's Avatar
View skewe's Photo Gallery
ATF Dexron III
Check your manual, it should say Dexron II or ATF Dexron III
Better to get it from ur toyota dealer to just have the same power steering fluid.
skewe is offline   Reply With Quote
Old 04-01-2005, 09:54 AM   #7 (permalink)
anyone know how to flsuh it?
matt
Old 04-01-2005, 10:55 AM   #8 (permalink)
[QUOTE=97camryman]Thats really bad!!! You totally screwed it up if the fluid is different from factory, the seals will swell an burst eventully. Save up for new parts and dont do that again!
J/K you should be fine. In the future try and use recommended fluid.[/QUOTE]
aww crap....i didnt even see taht....nice one!
Old 04-01-2005, 01:47 PM   #9 (permalink)
Use a line wrench and open up one of the lines into the rack, put something under it to catch the fluid. Now open the PS cap where you would fill it. Then get in your car, and turn the wheel left to right until you hear no more fluid is coming out. Add more and repeat once and it should be cleared out near 100%
