PCV Valve - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-30-2005, 11:07 PM   #1 (permalink)
View tightcamry129's Photo Gallery
PCV Valve
Hey guys, I met a dude that had a gen 3 camry and he did something funny with his pcv valve. You know how pcv valve reroutes wutever back into the intake manifold right? He told me that he didn't want to put back contaminated source back into the intake manifold from the head so he put a small breather filter on the head and no connection into the manifold. So basically he disconnected the pcv valve from going into the manifold. Is this safe? Any positive things come out of this?
tightcamry129 is offline   Reply With Quote
Old 03-31-2005, 12:01 AM   #2 (permalink)
View Sundown311's Photo Gallery
Your gas milage might go down. And the engine might have higher output with the cold air instead of the recycled gas. By the way shouldn't the filter be on the manifold?
Sundown311 is offline   Reply With Quote
Old 03-31-2005, 01:25 AM   #3 (permalink)
The Other White Meat
terrastrife's Avatar
he said hte filter is on the head... yes thats fine but... what do you think oil catch cans are for?
terrastrife is offline   Reply With Quote
Old 03-31-2005, 07:42 AM   #4 (permalink)
1984 22R
View Bmaintz's Photo Gallery
Pulls gases out of engine...
The purpose of the PCV is to PULL out gases (blow-by) from the crankcase.... Your oil will become MORE contanimated over time resulting in SLUDGE build-up.... Bob
Bmaintz is offline   Reply With Quote
Old 03-31-2005, 08:05 AM   #5 (permalink)
deviate from the absolute
Knailgun's Avatar
Gameroom cash: $285780
iTrader Score: 40 reviews
View Knailgun's Photo Gallery
vent on the crankcase will get rid of the gases...but you may have probs down the road
version 4.0 is here http://www.toyotanation.com/forum/sh...56#post3188156
Knailgun is offline   Reply With Quote
Old 03-31-2005, 03:58 PM   #6 (permalink)
what kind of problems?
Old 03-31-2005, 04:11 PM   #7 (permalink)
1984 22R
You need to THINK a little...
I can't believe that you can't figure it out that messing with your PVC system won't harm your engine......!!!!!.... Say you put your head inside a plastic bag & breathed normal, after a while your air is NO GOOD & you DIE.... Same for your Camry engine, it needs fresh air so your oil won't become loaded with dillutents such as acid, unburned gas & oil vapors..... Do you now understand???....Bob
P.S...Not upset, just trying to get the point accross.....
Old 04-01-2005, 08:44 PM   #8 (permalink)
wait I'm sorry, I'm new at this and I'm just trying to understand. If I don't connect the crankcase to the intake manifold with the pvc valve, the crankcase doesn't get enough clean air and it'll go bad?
Old 04-01-2005, 10:00 PM   #9 (permalink)
1984 22R
Yes, the oil will go bad in a hurry, thus taking the life out of your engine..... The oil is the life blood of your engine & must be kept clean & fresh....
Old 04-01-2005, 10:16 PM   #10 (permalink)
Zzzz
CrawlingEye's Avatar
View CrawlingEye's Photo Gallery
Are you sure you're not thinking of the EGR valve?
ie: Exhaust Gas Recirculation valve?
-mark
'93 Camry LE (5S-FE)
CrawlingEye is offline   Reply With Quote
Old 04-01-2005, 10:32 PM   #11 (permalink)
1984 22R
I'm sure
Yes I am sure, the EGR value is also needed....
Old 04-02-2005, 12:18 AM   #12 (permalink)
Zzzz
Bmaintz, the EGR valve isn't need except for emissions purposes.
I wasn't asking if it was needed, I was asking the thread poster if this is the valve he intended to type, and not the PCV, as he described the EGR system.
-mark
Old 04-02-2005, 02:06 AM   #13 (permalink)
poor college student
userlain's Avatar
View userlain's Photo Gallery
The safe thing to do would be to get a 'catch can'.
Essentially it filters out the crap from the PCV. You can connect it to your intake manifold, but you don't really need to. You just put breather filters on the intake manifold hole and the outlet on the catch can.
http://search.ebay.com/oil-catch-can...trypageZsearch
'91 Camry @ ~162,900 miles
userlain is offline   Reply With Quote
Old 04-02-2005, 04:01 AM   #14 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
A catch can collects the oil droplets, while vapors are recirculated back into the engine.
You can't put a filter on the hole on the intake manifold. If you did, you'd have a nasty vacuum leak. You'd have to plug the hole.
The idea behind a pcv (positive crankcase ventilation) valve is that the vacuum in the intake manifold pulls the valve open. This lets the vapors from the crankcase recirculate back into the engine (thru the intake manifold).
A pcv valve in a one way valve. In other words in only flows in one direction.
PCV is a sealed system (from the factory anyways). Nothing vents to the atmosphere. If were talking about a 5S-FE, the pcv valve plugs into the top of the valve cover. The other end connects to the intake manifold.
"Skoolin' the unlearned!"
Old 05-18-2005, 12:45 AM   #15 (permalink)
Registered User
View qprint's Photo Gallery
Is there aPCV valve on the Gen 5 V6 LE ? And Where is it ?
Thanks in advance
qprint is offline   Reply With Quote
