Fuel Filter replacing was a HUGE success!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-01-2005, 08:39 PM   #1 (permalink)
View tightcamry129's Photo Gallery
FOr those of you that are worrying or dreading to replace the fuel filter on your gen 4's, don't even worry about it. I just did mine today considering almost everyone that I talked to or read about, stopped me from doing it.I heard horror stories about bent fuel lines and leaking filters and gasoline igniting to huge flames. My local mechanic told me it would be about $50 for a filter and $40 for labor for a total quote $90. I insisted on doing it myself with care and bam! I replaced it in less than 15 minutes. My advice for you guys it to just be careful when you tighten the filter at the top and the bottom. Hand-tighten than use a wrench.
tightcamry129 is offline   Reply With Quote
Old 04-01-2005, 11:58 PM   #2 (permalink)
View ptran's Photo Gallery
was there a lot go gas spillage after the intake and out lines where removed?
ptran is offline   Reply With Quote
Old 04-02-2005, 02:55 AM   #3 (permalink)
NO not at all, maybe a teaspoonful... not much at all
Old 04-02-2005, 08:37 AM   #4 (permalink)
Where are we going today?
skewe's Avatar
View skewe's Photo Gallery
4th Generation
do i need to worry about air bubbles in the fuel line, etc
how hard is it to get to?
i have a gen3 and it was an ass to do so, thus, I still have the gen3 filter sitting there.
skewe is offline   Reply With Quote
Old 04-02-2005, 09:44 AM   #5 (permalink)
Triple A Whore
Edmond's Avatar
View Edmond's Photo Gallery
The upper nut on my fuel filter wouldn't even budge. As far as I know, it's been in there since 1994. I tried to loosen it but it just wouldn't budge.
Maybe I'll try to change it when the weather gets warmer. Just thinking about getting to the lower nut has me
Edmond.
Edmond is offline   Reply With Quote
Old 04-02-2005, 10:18 AM   #6 (permalink)
I’m not going to say no
View Pishposh30's Photo Gallery
4th Generation
Quick Question, will a fuel filter for a 90 (or maybe it was a 91) Celica fit a 97 Camry? I did a quick search online and the 97 Camry Fuel Filter isn't the same part as the 90 Celica Fuel Filter. However my father said it would fit in a 97 Camry does this sound right to you guys?
Pishposh30 is offline   Reply With Quote
Old 04-02-2005, 11:41 AM   #7 (permalink)
Triple A Whore
Edmond's Avatar
I would just go buy the filter for the Camry. They're not expensive, probably $25 or so, $35 max. Why even take a chance?
Edmond.
Old 04-02-2005, 01:21 PM   #8 (permalink)
There is no substitute.
EKam's Avatar
Gameroom cash: $700865
iTrader Score: 6 reviews
View EKam's Photo Gallery
Mine had the same issue. That's why I paid a mechanic to do it.
18/6/08 - Sayonara Kamuri!
EKam is online now   Reply With Quote
Old 04-02-2005, 07:05 PM   #9 (permalink)
View Ken4's Photo Gallery
There is also a filter sock attached to the fuel pump in the fuel tank that you should consider replacing. And there is a third fuel filter called the return fuel filter also located on the fuel pump assembly.
Ken4 is offline   Reply With Quote
Old 04-02-2005, 09:35 PM   #10 (permalink)
[QUOTE=Ken4]There is also a filter sock attached to the fuel pump in the fuel tank that you should consider replacing. And there is a third fuel filter called the return fuel filter also located on the fuel pump assembly.
where are these filters located? I have a 2000 v6 and have only found the fill filter next to the airfilter on drivers side.
Old 04-03-2005, 12:44 AM   #11 (permalink)
In the fuel tank. Remove your rear seat and you will see it.
Old 10-21-2005, 12:57 PM   #12 (permalink)
View xxpanipuri's Photo Gallery
i had the toyota dealership do mine the first time i'm going to try and replace mine this weekend and hopefully i should be able to loosen the nuts...
xxpanipuri is offline   Reply With Quote
Old 10-21-2005, 01:06 PM   #13 (permalink)
so how many fuel filters..does the 2000 camry v6 have i need to replace mine
its been about 100k miles since i've had it replaced. and lately the car is idling rough and under 2k during acceleration it hesitates!
also going to replace the pcv valve while i'm at it
i need to go home and crack open the service manual and find out where all the fuel filters are and replace them...
do you guys recommending all the fuel filters or start with the one under the hood which is the easiest?
Old 10-21-2005, 02:15 PM   #14 (permalink)
View keylogger's Photo Gallery
It would be nice to have some pics on how to do it. But you know what they say, beggars cant be choosers.
Willing to learn from "experienced" tunners. I just need the parts.
keylogger is offline   Reply With Quote
