window won't stay up - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-02-2005, 11:56 PM   #1 (permalink)
View RealLiveMD's Photo Gallery
I have an 03 camry xle. The driver side ( Motor) regulator became loose and the window got off track. I tightened the bolts on the regulator and now the window is on track, but the travel height needs to be adjusted because it automatically reverses when I roll it to the top. How do I adjust the height... or is something else wrong.
RealLiveMD is offline   Reply With Quote
Old 04-03-2005, 09:14 PM   #2 (permalink)
come on guys, really need some help
Old 04-05-2005, 02:16 AM   #3 (permalink)
Camry Freak
98CamryLE's Avatar
View 98CamryLE's Photo Gallery
How many miles do you have??? If you have under 36,000 miles, take your car back to a dealer and have it fixed under warranty.
I believe that 03 XLE camrys have auto-up as well as auto-down functions on the driver's window-(one touch raises or lowers the windows all the way) The auto-up function has a sensor that will reverse it if it senses something in the window's path.... so that a child's arm won't get caught and stuck. It might be the sensor needs to be reset or something... maybe because the window got off track. Hope this helps.
-Robert
2007 Camry Hybrid
98CamryLE is offline   Reply With Quote
Old 04-06-2005, 07:16 PM   #4 (permalink)
40000, and you're right about the auto function. I don't think there is a sensor outside of the regulator though. However, thanks for the advice.
