piddley stuff - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-03-2005, 04:37 PM   #1 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
2nd Generation piddley stuff
OK guys, 2 problems,
1, I cant figure out how to get the under dash speakers out
2, My throttle butterfly is hanging up when warmed up and it idles about 2k if i slowly get off it, i can tap the gas and it falls right down,. I cleaned the blade area and made sure the cables werent hanging up, and it still hangs up, is a throttle body in my future?
Old 04-03-2005, 06:08 PM   #2 (permalink)
poor college student
userlain's Avatar
View userlain's Photo Gallery
You have to remove the kick panels and lower dash to get at the speakers. Also, there are bolts hiting behind little plastic coin holders, just pull the coin holders out. It's a huge apin in the ass.
'91 Camry @ ~162,900 miles
userlain is offline   Reply With Quote
Old 04-03-2005, 07:04 PM   #3 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
I found the twin bolts on each side on the drivers side knee pad, where are the coin holders for the hidden bolts?
Old 04-03-2005, 07:50 PM   #4 (permalink)
userlain's Avatar
Sort of near the steering column
Old 04-04-2005, 03:17 AM   #5 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
I posted this a few days ago:
http://www.toyotanation.com/forum/t72809.html
"Skoolin' the unlearned!"
Old 04-04-2005, 03:13 PM   #6 (permalink)
Gameroom cash: $304455
fredk,
2. You have to clean the throttle body again. This time have someone hold the gas pedal to the floor with the engine off so the back side of the throttle valve is exposed and can be cleaned. Also, clean the area all around the inside of the throttle body where the throttle valve sits when it returns to it's closed (vertical) position. You can use your finger and spary throttle body cleaner, if you can reach in that far, or use a very soft rag wrapped around a screwdriver soaked in throttle body cleaner.
Mike
