New prob, please help me - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-05-2005, 06:34 PM   #1 (permalink)
View rgravelle's Photo Gallery
Canada New prob, please help me
Finally my car work, but.. i think it was because of the rain and the humidity... but anyone know why ?? is it maybe a piece of my car is broken.. or like the alternator have almost, no more "power" or... i dont know.... he had a big difficultys to start it.. i start it today with the big sun and the tralalala...... i needed to boost it with my boost pack... so
is it the alternator?? cause i went to canadian tire to test my battery and he said that it was good again...
anyone had or have the same prob?? or i just need to drive it in a pool of acid :P
rgravelle is offline   Reply With Quote
Old 04-05-2005, 10:38 PM   #2 (permalink)
camry-4-ever's Avatar
View camry-4-ever's Photo Gallery
Sounds like you have a loose connection. Check all connections from batt. to starter and to ground. Starter might be going out.
camry-4-ever is offline   Reply With Quote
Old 04-07-2005, 07:20 PM   #3 (permalink)
mmmm well do you know where is the "ground" ppl tell me that i dont know where is it.. is it on the motor?? and the starter, ill check that up and ill talk to you bout that
Old 04-07-2005, 07:35 PM   #4 (permalink)
View Ken4's Photo Gallery
Doesnt crank? It could be the starter. It is common for the starter brushes to get worn out. If your alternator lamp on your dash doesnt light up, it is unlikely it is the alternator.
Ken4 is offline   Reply With Quote
Old 04-07-2005, 07:39 PM   #5 (permalink)
well yes its cranking... but need a little more power and it will be okay.. .always happen when its big rain outisde... and yea on my board the light: Charge(battery design) and hand brake etcs.. are like flashing
its not the starter i think.. cause i dont here the TIC sound...
Old 04-07-2005, 07:42 PM   #6 (permalink)
deviate from the absolute
Knailgun's Avatar
Gameroom cash: $285780
iTrader Score: 40 reviews
View Knailgun's Photo Gallery
water in the distributor...sounds plausable.....my 2 cents
version 4.0 is here http://www.toyotanation.com/forum/sh...56#post3188156
Knailgun is offline   Reply With Quote
Old 04-07-2005, 07:47 PM   #7 (permalink)
what is the distributor ???
Old 04-07-2005, 07:53 PM   #8 (permalink)
Well if your battery is ok, clamps are tight, starter is ok........I agree, it is most likely your alternator, alternator brushes, or the voltage regulator (also on the alternator).
Old 04-07-2005, 07:55 PM   #9 (permalink)
well then... should i change the alternator? ... is it better a new one or i can go to a scrap yard ?
Old 04-07-2005, 07:56 PM   #10 (permalink)
Knailgun's Avatar
eek, get new alternator...used ones are usually trash w no warranty...get new, you'll thank yourself in the morning
