suspension rattling when turning - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-06-2005, 09:40 PM   #1 (permalink)
View loserboy's Photo Gallery
4th Generation suspension rattling when turning
My 00 camry has been making rattlings noise while making a right turn for quite a while, sound comes from front driver suspension. But it only happened when i was making a sharp right turn. Now the sound occurs even on low speed and its getting worse. I did a search on the forum and it seems strut mount seems to go bad, but alot of people said sound occurs when running over bump or rough road. Mine drives perfectly fine and does not making any noise at all (except for pssssh sound) when going over bump or rough roads. I've had a accident that hit the front driver side tire pretty hard, and had whole front driver side suspension rebuilt. I would greatly appreciate it if someone can give me some advice on what the problem is.
Also on side note, i moved into a new neighborhood. And i'm trying to find a reliable mechanic here. Whats a good way to test if they are out to rip me off or not? i usually use "my gad pedal is sticking" question, and see if they try to rip me off or not. Thank you!
loserboy is offline   Reply With Quote
Old 04-07-2005, 07:37 AM   #2 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
lol well look under your car at the cv boot that might be torn and making that noise .... if it is take to a mechanic and see what they say ..... if they say anything but cv there a rip off
^ and leaving it that way!
Old 04-07-2005, 07:49 AM   #3 (permalink)
Mitsubishi Diamante Owner
CDub LXi's Avatar
View CDub LXi's Photo Gallery
Yeah cv boot/axle is what I'm thinking but that's more of a clicking noise than a rattling noise... so I'm not sure.
Maybe just check the bolts that hold the suspension together since you've had it redone. Maybe they're not tight enough and when you turn the strut is moving some.
CDub LXi is offline   Reply With Quote
Old 04-07-2005, 08:13 AM   #4 (permalink)
thank you guys!
