5s-fe losing oil pressure (help) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-08-2005, 03:33 PM   #1 (permalink)
bt6
View bt6's Photo Gallery
3rd Generation 5s-fe losing oil pressure (help)
Hello everyone,
I've got a Gen 3 Camry 4cyl. About three months ago while driving down the freeway my engine lost all oil pressure....well since then my engine has been rebuilt twice and when I got it back the mechanic swore up and down that everything was ok.
On my way home from school the same thing happened, as I sat at an intersection the oil pressure dropped and the oil light came on. WTF is going on here, what would be causing this to happen?
Any help is greatly appreciated on what the problem may be, cause I really don't want to sell my car.
Thanks in advance,
brian
bt6 is offline   Reply With Quote
Old 04-08-2005, 07:35 PM   #2 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
ya need another mechanic
Old 04-09-2005, 07:46 AM   #3 (permalink)
Mr. Toyota
View TadS's Photo Gallery
Is there a leak? If so, where is the oil going? It has to be going somewhere.
TadS is offline   Reply With Quote
Old 04-09-2005, 08:47 AM   #4 (permalink)
Gameroom cash: $304455
Was the oil pump replaced during either of the 2 rebuilds? That is the most likely culprit, if you are actually losing oil pressure. Do you hear any strange engine noises when you get these pressure drops? Are you sure you are actually losing oil pressure when this happens, or is the oil pressure sending unit or it's wiring simply faulty? A tech can simply replace the sending unit temporarily with a mechanic gage to actually get a true oil pressure reading. This should cost very little.
Mike
Old 04-09-2005, 12:53 PM   #5 (permalink)
bt6
Mike,
Thanks for the answers. The oil pump was supposedly replaced both times. I'm pretty sure it's not the sending unit because I have an aftermarket oil pressure gauge as well and both are reading low pressure.
there seems to be a lot of valve chatter since it happened. It will hold pressure for a little while but after driving around for about 25 minutes it will drop when the car is in gear, sitting at idle.
Thanks again for the help,
brian
Old 04-09-2005, 05:53 PM   #6 (permalink)
MCH Engineer in training
Location: A-town, Doylestown, & Northampton, PA; Morgantown, WV (WVU COE)
View ag6286's Photo Gallery
soundz like your mechanic doesnt know how to replace freeze plugs properly
ag6286 is offline   Reply With Quote
Old 04-09-2005, 08:17 PM   #7 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
freeze plugs?
Old 04-10-2005, 08:30 AM   #8 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Freeze plugs have nothing to do with low oil pressure.
Their purpose is to prevent the block from cracking, should the water/coolant inside the block freeze.
Water expands as it freezes, so the freeze plugs pop loose.
I'm with Mike, I would start by checking the oiling system (pump, pickup, etc..).
"Skoolin' the unlearned!"
Old 04-10-2005, 09:45 AM   #9 (permalink)
Brian,
The mechanic who rebuilt the engine should replace the oil pressure sending unit with the mechanic gage and take it for a ride. He should be doing this for free, especially if he is the one who rebuilt the engine both times.
Just curious, does the aftermarket gage get it's signal from the same source as the OEM sending unit? Just thinking outloud here.
88 LE also has an interesting thought here. It is possible that something is clogging the oil pickup down in the pan area. A tech could take off the oil pan gasket and remove the pickup and check it for obstructions.
Mike
Old 04-10-2005, 11:48 AM   #10 (permalink)
Grenaded piston
88 LE's Avatar
I've seen it happen.
My buddy had a valve lash cap fall off from a 351W. It broke into little chunks.
A chunk of it was in the oil pickup, we unbolted the oil pickup and you could hear it rattling around inside.
Another chunk of it got into the oil pump and seized it.
Some nasty stuff.
Probably due to your low oil pressure issue, which caused the valve train to not be sufficiently oiled.
Old 04-10-2005, 12:22 PM   #11 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
Old 04-10-2005, 03:33 PM   #12 (permalink)
View 500KCamry's Photo Gallery
When oil pressure was lost, did you hear it, i.e. valve chatter? If not, your problem is the sending unit ... they do fail. Otherwise,
Is the oil the correct grade?
Is the filter clogged?
The oil pump can be changed without removing the pan, was it really changed?
I'd remove the pan though, and clean it of sludge and make sure the pickup strainer is removed and cleaned too. The pan gasket is made from silicone, a couple of the front pan screws are difficult to put in. The engine can be temporarily tilted to get them installed.
85 LE 2SE 500K km - died trying to push a semi off the road
95 LE 5SFE 530K km, 530K km changed engine, 549K km second engine died, now 554K Km running with a 98 5SFE block and head
01 XLE V6 310K km
500KCamry is offline   Reply With Quote
Old 04-11-2005, 12:42 AM   #13 (permalink)
I'm a Mac
zoni's Avatar
View zoni's Photo Gallery
i guess the oil pressure sender to be bad... if its the same used in the oem AND aftermarket gauge.
Dave Zoni
Latest 3S-GTE Swap Pics
zoni is offline   Reply With Quote
