take them out of the car and stuff the inside of the headlights with paper towels. leave it for a bit until there no more moisture. i do it to my tail lights all the time becuase water gets into them
I'd say try putting some dessicant packets in them, but I don't know where to get it except at my work and in stuff you buy. Ya know the silica gel packets that say "DO NOT EAT" on them? Either that or a hair dryer.
what type of car do you have . if the headlights are clear then it would leave streaks but if its not then you dont have to worry about that. you can put them in the oven to open them and clean them really good
ur head lights must be leaking... are both headlights showing moisture in them??? if so u may need new lights. silica packets may be a temporary solution but if you dont wanna have the same problem every few months then fix it right.
Lol I just bought these headlights, they aren't leaking.
take them back, they ARE leaking. headlights are meant to be sealed.
youve got moisture in there, when its cold, the moisture condenses and causes water droplets on the glass, when it warms up, the moisture turns to gas, causing it to go away.
take the headlight out, when its nice and dry outside, open it up, wipe it down, reseal it and reinstall. you should be good to go then.
My garage
1991 Nissan Maxima SE V6 5SPD - daily beater - Sold
1988 VW GTI 1.8l 16v - weekend beater - Blown engine
2005 Elantra GT sedan 5spd - Woo, no more beatup cars!
On a warm, sunny day, remove the bulb, leave the hood opened, and let it sit for a few hours, by which time, all the moisture should have evaporated out. Then replace the bulb. If it shows up again, you do have a leak. This method worked for me.
heat 'em up, then spray around the outside with silicon sealant. Make sure to mask off whatever you don't want to get sealed though (otherwise you'll have some funny lookin' headlights).
