Please Help!!! p1135 Engine code - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-08-2005, 08:05 PM   #1 (permalink)
View Jettdawg's Photo Gallery
Well hey guys. I recently got a check engine code p1135. I looked it up and it said Air-Fuel Sensor Heater Circuit Response. So I checked the continuity to the first o2 sensor and it showed that it was broke. I checked the second o2 by the cat and it was fine so i left it alone. so i replaced the o2 sensor and reset the computer and shortly after the car has been on i get the same code again. What do i do???
2001 Camry LE
Jettdawg is offline   Reply With Quote
Old 04-09-2005, 08:23 AM   #2 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
did you use a ome toyota one or a aftermarket (like bosch)
the aftermarket usaly has you splice wires .... just make sure you sliced them right if after market
^ and leaving it that way!
Old 04-09-2005, 04:31 PM   #3 (permalink)
Yea i used a universal o2 sensor. but i checked the continuity in between the the two heaters wires (3, 4) on the harness and it had continuity. so that means the connections are good in the heater wires, so there shouldnt be a reason why it still displays p1135. i noticed that there is very low continuity in the heater wires that go to ECU.
2001 Camry LE
Old 04-10-2005, 10:36 AM   #4 (permalink)
for those of you who have installed universal o2 sensors, can you tell me if i hooked it up right. i put the two black heater wire from the original harness to the two white wires off of the universal bosch one . then i hooked up the original blue to the black on the universal and the white to the gray. does this look right? i went by the type B o2 sensor on the diagram
2001 Camry LE
Old 04-10-2005, 08:42 PM   #5 (permalink)
Always Under Construction
View whocares04's Photo Gallery
actually when i went to autozone i bought the OEM spec where u don't have to splice and it was by Bosch and i haven't had any problems (plus looking at the new one, it looks alot nice and seems like it would function better just by the design...
-Matt
When in doubt, use the search function (link)...no one is spoon fed...
whocares04 is offline   Reply With Quote
