Originally Posted by KevinLi
1. Do I have to undo camshaft to replace valve stem seal of 1mz-fe? Are there any rocker arms inside? I do not think so.
2. I know I do not need to uninstall cylinder head to replace valve stem seal. Then do I need a special valve spring compressor to undo the keeper? I believe the standard valve spring compressor is designed for undo keeper after remove cylinder head. Am I right?
1. Yes you have to remove the cams. There no rockers arms.
2. I've heard of special tools to do what you said, but I don't know much about them.
To remove the valve springs with the cylinder head(s) unbolted, you need a overhead valve spring compressor. It looks like a C-clamp. Sears has them for about $25 or so.
The other type of valve spring compressor will not work, as the springs are within the head (ie: their not exposed).
http://www.mytoolstore.com/kd/kdengi13.html
