...When i hit bumps.. i hear a Ca thudd .. (not REALL loud or anything.. but its there)
im ganna get my tires alligned and there tell me exactly whtas amatter. but in the mean time..
any one knwo what it could be ? suspention ? but .. why the clicking noise
1998 Camry V6 5 speed
Red Tint,Viper Hood Ornaments
White
Camry 4 Life
Most likely the upper strut mounts are shot. This is a known problem on the generation 4 Camrys. Toyota has redesigned these strut mounts twice to correct the problem, although they won't recall these cars; it's not an emission or safety related issue. This is not a cheap fix as the struts have to come out to do this and then the springs have to be removed from the struts. Most people ignore it till it's time to replace the struts and replace the strut mounts then. I called Toyota corporate about this a few months ago. The customer service rep said there is no recall or special service campaign covering this "but if enough people call in to complain about it at the corporate level Toyota just might decide to do something about it". The phone number is 800-331-4331, so everybody with a generation 4 Camry should start calling and complaining. Maybe we can get them to issue a recall for this problem.
mom says it might be a tire rod or something like that..
maybe yall are talking abot the same thing..
and she says the buzzing sound is coming from the muffler
White
Camry 4 Life
I Have A 99 Camry 112k Miles. In The Process In Changing The Front Strut Mounts. Changed One Already Didnt Have The Money Up Front For Both And Labor. One Was $230 Part And Labor
Take it in for an alignment and let them diagnose the problem. They won't do the alignment if you have a problem with the suspension or steering. You don't have let them fix it, but return to them for the alignment when you've had it fixed. Should give them somthing for the diagnosis.
I think you could have a balljoint problem, or one of the bushings for the control arm is worn. Either will give you a clunk on a rut.
85 LE 2SE 500K km - died trying to push a semi off the road
95 LE 5SFE 530K km, 530K km changed engine, 549K km second engine died, now 554K Km running with a 98 5SFE block and head
01 XLE V6 310K km
yeah.. its only the front that is doing.. it.. back is fine.. hate the stupid noise though.
and hey mescalito.. could ya send me a Pic of where under hood the Bolts are ? maybe they are just loose.. ( ive had a LOT of loose bolts ))
just pop the hood and look to your left/right - on the very edge there are three bolts in a triangular pattern with one in the center - those are your strut bolts
while ya checking those bolts.. look at the bit in between it all that black area with teh big bolt.. yoreu nto looking at the big bolt itsefl but the area around it.. it should not be open... push down on ya car, it should all move together.. if the middle bit isnt moving with te rest of ya car (or its loose).. the strut top is gone,
yea i had that SAME EXACT problem and i got so fed up with it that i went to AutoZone, got new strut mounts and got a whole new suspension setup while i was at it. It fixed the problem
~No more noise~
santino
__________________ SOLD! 97 Camry V6 TRD
Proud new owner of a 2005 Scion TC
5-speed baby!
the struts are tight.. 3 Triangle Nuts.. with Black thing in the middle.. witha big bolt in the middle of it. yah
the black thing moves.. JUST a lil bit when i lift up on the car. but other than that.. they all seem tight
the black thing seems pretty secure
White
Camry 4 Life
i have the same noise but coming from the rear of my car. the funny part is that my car is only 2 months old. what should i do. should i take it to the dealer?
