Painting painting center tail light! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-11-2005, 07:19 PM   #1 (permalink)
3VZ-FE Camry
View sanengo's Photo Gallery
I want to paint that center tail light of my camry. My last experience with spray cans was dripping uneven and bubbly paint.
Any tips for doing this job? I have 400 800 and 1000 grit sand paper. Can anyone guide me on how to paint this thing?
Thanks
sanengo is offline   Reply With Quote
Old 04-11-2005, 07:39 PM   #2 (permalink)
Always Under Construction
View whocares04's Photo Gallery
search....
-Matt
When in doubt, use the search function (link)...no one is spoon fed...
whocares04 is offline   Reply With Quote
Old 04-11-2005, 07:43 PM   #3 (permalink)
3VZ-FE Camry
Help me, I've tried "center tail light" "paint" "painting" paint center tail light" and all of them come with mention of painting the center tail light but no actual helpfull tips about the process.
Thanks so much for your help
Old 04-11-2005, 07:59 PM   #4 (permalink)
poor college student
userlain's Avatar
View userlain's Photo Gallery
What color are you trying to paint it?
'91 Camry @ ~162,900 miles
userlain is offline   Reply With Quote
Old 04-11-2005, 08:24 PM   #5 (permalink)
3VZ-FE Camry
Black. Can I just sand it with 800 grit, and spray that touch up paint you buy at auto shop at the tail light? How can you minimize bubbling and dripping? Is there some other paint I should use? I don't mind if its not polished looking, but I would prefer it.
Old 04-11-2005, 10:38 PM   #6 (permalink)
View .tony. .riot.'s Photo Gallery
I think you should prime it first.
.tony. .riot. is offline   Reply With Quote
Old 04-11-2005, 10:58 PM   #7 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $397060
iTrader Score: 13 reviews
remember to wet sand
and if it's bubbling or dripping, you're doing it in WAYYYY too thick of layers....remember....thin layers....that's why as ^Tony there said...you should primer first....black primer...then your black....then clear coat....then buff like mad to get some shine....
but most importantly, wet sand between each layer
HaHa
Old 04-11-2005, 11:36 PM   #8 (permalink)
TN's Resident Car Whore!
dna59's Avatar
View dna59's Photo Gallery
I tried doing it myslef with regualr spray, but it just didn't work out for me. Only thing that worked for me was krylon fusion, then I just ended up taking it to be painted. But I'm sure if you have patience you can do it yourself and it'll be good.
http://www.xclusive.bz
Old 04-12-2005, 12:09 AM   #9 (permalink)
3VZ-FE Camry
Many thanks to you all much more helpful than the overrated search button. I will try wetsanding, primer, then sanding again, then the rest..
What is the difference between the touch up paint you buy and clearcoat?
Old 04-12-2005, 12:17 AM   #10 (permalink)
amerikim's Avatar
View amerikim's Photo Gallery
To prepare your surface is most important, wash in hot water and wipe with rubbing alcohol until you are sure no polish or oil are left. Sadpaper light and primer before paint. Paint at least 3 coats. 1 coat clear is okay, can go with two. No painting wet surfaces or over spraying,
Recommend you go junkyard and buy a spare for you to paint so you can go back if you dont like result,
old faithful
amerikim is offline   Reply With Quote
Old 04-12-2005, 12:23 AM   #11 (permalink)
3VZ-FE Camry
Thanks! how can I go about removing the center tail light? It seems to be stuck on after I removed the 5 visible bolts that were attaching it to the trunk. (3 bolts were under the fuzzy cover) Do I just need to pry it out?
Old 04-12-2005, 12:54 AM   #12 (permalink)
I think there are about 8 bolts, so keep looking for a few more. Once you have them all, then yeah, pussh from the inside and pull from the outside. It will be pretty stiff and sticky in there because you probably have never removed it before.
Old 04-12-2005, 01:09 AM   #13 (permalink)
camry> /RAPES\ <honda
Jagwire's Avatar
View Jagwire's Photo Gallery
hmm.. your talking about painting over your Light eh ? tight lil mod .. really add's to cuztom of ya ride.. i think i wanna do.. someeething like that to mine.. just make the light thinner.. more meaner lookin .. on a GEN 4 .. it should look tight these tips will help mez too thx
1998 Camry V6 5 speed
Red Tint,Viper Hood Ornaments
White
Camry 4 Life
Jagwire is offline   Reply With Quote
Old 04-12-2005, 05:23 AM   #14 (permalink)
Lex Zues!
RedPhoenix's Avatar
iTrader Score: 12 reviews
View RedPhoenix's Photo Gallery
There are 8. Behind your latch is one, you need to take that out. just keep looking. Be careful not to break your latch. I did, I cant use the key, if i do, it makes the inside trunk release cable pop off and then I dont have a working trunk... hard to fix with my system in there.
Anyways, there are 8.
Sold ^
Originally Posted by dysk8forlife
supercharger whine>girlfriend whine
RedPhoenix is offline   Reply With Quote
Old 04-12-2005, 01:21 PM   #15 (permalink)
deviate from the absolute
Knailgun's Avatar
Gameroom cash: $285780
iTrader Score: 40 reviews
View Knailgun's Photo Gallery
easy alternative is to get a rear piece off of an SE....I have one and no you can't have it
version 4.0 is here http://www.toyotanation.com/forum/sh...56#post3188156
Knailgun is offline   Reply With Quote
