P'n'P - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-13-2005, 09:46 AM   #1 (permalink)
Pissed
View Camryamnesty's Photo Gallery
P'n'P
Well im taking my cylinder head in today to get it ported and polished.... im unsure whats really going on with it, but ill keep updates and ill post some b4 and after pics!
Camryamnesty is offline   Reply With Quote
Old 04-13-2005, 12:38 PM   #2 (permalink)
Gameroom cash: $147537
You should port match exhaust and intake manifold also. Are they gonna do multi-angle valve job?
Old 04-13-2005, 12:56 PM   #3 (permalink)
Toysrme's Avatar
View Toysrme's Photo Gallery
Cool
Good call!
The port matching itself is the least important of *any* port job. You get more gain by sanding the areas before the injectors as flat as you cans tand (taking the texture off) than you do by gasketmatching. (even if there is a huge gasket differance).
If you've got a v6 expect 25hp if they do a good job. If they unshroud the valves, expect 30.
They need to concentrate a lot of their efforts on sanding away the short side radious (if you get it back and it's not a gental round corner say half a finger digit long, you need to spend two hours with strips of dsand paper on the end of your finger, sanding it down gental and smoothe)
Between that and simple bowl reshaping, it's impossible for them to gain an extra 10 hp on that, through any efforts. (IMHO)
If you can suffer the cost of having them buy two extra valves (they'll destroy two unshrouding them) and the associated valve job afterwards. Defiantely have that done.
Unless it's a godly machine shop, it's next to impossible to fit even 1mm larger valves on the intake side. 2-3 mm is going to be the limit on the exhaust side.
When you get the heads back look into the exhaust port. If they haven't done much work in that area, you need to take some sandpaper on your finger (and a dremel with a flexi shaft attachement) and smoothe absilutely every bit of the sand texture out of the exhaust side that you can.
The less carbon that builds up there, the higher the flow you have.
(Porting the exhaust manifold isn't going to get you much, if anyhting, at all. Skip it)
AIM/Yahoo Toysrme257th
Now with Turbo!
Old 04-13-2005, 04:45 PM   #4 (permalink)
VeeZed
JetspeedCamry's Avatar
View JetspeedCamry's Photo Gallery
Cant wait to hear the results.
1988 Toyota Camry 2VZ-FE E153
1972 Ford Mustang Sprint "F" 351C-2V 4SPD
1973 Ford Mustang Mach 1 "Q" 383C-4V FMX
JetspeedCamry is offline   Reply With Quote
Old 04-13-2005, 05:26 PM   #5 (permalink)
Pissed
Actually, its got a bent valve, im replacing all of them, and my uncle works at a machine shop, and i figured, well since i already have the cylinder head off, and my uncle works there.... hmmm "ive told you you were my fac uncle right?"
Old 04-13-2005, 05:48 PM   #6 (permalink)
Pissed
PICS!
Intake side
Block Side
Valve cover side
Old 04-13-2005, 07:31 PM   #7 (permalink)
Toysrme's Avatar
Cool
Dirty! I want a shot of your pistons!
Freak your uncle out, and tell him you want yours to look like this!
Now with Turbo!
Old 04-13-2005, 07:32 PM   #8 (permalink)
I has boost..!
Razo-E's Avatar
View Razo-E's Photo Gallery
looks like gold..
1986.5 5-speed '91 7MGE
1989 5-speed TURBO Targa (NA->7MGTE) BPU and lots of rare/JDM/Euro stuff
1992 5-speed hardtop - 2JZ-GE
2005 Scion xB - no longer stock
Razo-E is offline   Reply With Quote
Old 04-13-2005, 08:18 PM   #9 (permalink)
VeeZed
Far out, thats taking polishing to a new level!!! I didnt know polishing it ACTUALLY makes it polished like that!! WOW
Old 04-13-2005, 10:02 PM   #10 (permalink)
Pissed
heh, b 4 i put the head back on i think i might have the blocke bored and get some new pistons... nore 100% sure as of now. I would love to though
Old 05-06-2005, 12:49 PM   #11 (permalink)
Pissed
Just contacted my uncle, and turns out he'll be done on monday!!!!!!!!! yay then ill slap the bad boy on and hopefully be ready to go!
Old 05-06-2005, 04:37 PM   #12 (permalink)
Don't bore the block, just get higher compression piston.
Unless you're planning for turbo.
Old 05-06-2005, 05:27 PM   #13 (permalink)
The Other White Meat
terrastrife's Avatar
hijack...
i found a spare 3vz-fe! time to figure out how much they want for the heads! :P
terrastrife is offline   Reply With Quote
Old 05-06-2005, 08:10 PM   #14 (permalink)
View thisisntjoew's Photo Gallery
That polishing is AMAZING! How much money did that set you back (if you dont mind me asking)??
thisisntjoew is offline   Reply With Quote
Old 05-06-2005, 09:16 PM   #15 (permalink)
Turbo-Yota power
Jzs147-RR's Avatar
View Jzs147-RR's Photo Gallery
Polishing like that actualy can reduce performance ask a good shop they leave some areas rough to increase air turbulance ..Still looks sick polished like that ..
5sfe powered turd ...
Jzs147-RR is offline   Reply With Quote
