5SGTE Problem! Please help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-13-2005, 11:27 AM   #1 (permalink)
View draco12369's Photo Gallery
Question 5SGTE Problem! Please help
Hey I got a problem putting together my 5SGTE. I got a 92 5SFE block out of a Celica and a 92(i think) head off of a 3SGTE motor. Everything bolted up fine just after putting on the timing belt and spinning the crank a few times the piston taps one of the valves. I believe it is the exhaust vavles that are hitting the piston because they are a little longer than the 5SFE exhaust valves. Is there anybody who ran into this problem and can help me fix this timing problem??? Thanks for any response.
draco12369 is offline   Reply With Quote
Old 04-13-2005, 12:53 PM   #2 (permalink)
Rocket Surgeon
woody's Avatar
View woody's Photo Gallery
did you do a bunch of machining to the head or block?
or is it timed top dead center?
I want to try this sometime. I think that the 3sgte is a non interference engine to begin with anyways, so this shouldn't happen... but I am not a 3sgte pro...
woody is offline   Reply With Quote
Old 04-13-2005, 01:39 PM   #3 (permalink)
Zzzz
CrawlingEye's Avatar
View CrawlingEye's Photo Gallery
You can cheat and pickup a thicker headgasket and simply run that. Comectic makes them for the 5S-FE and I know horsepowerfreaks.com carries them. Just search under celica (camry will for some reason not show all of them).
If you get an oversized headgasket this should cure your problems. I would suggest that you just get new (bowled) pistons with lower CR anyway. If you intend on boost, this will save you loads of time while the engine is already out of the car.
-mark
'93 Camry LE (5S-FE)
CrawlingEye is offline   Reply With Quote
Old 04-13-2005, 09:26 PM   #4 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $308575
Ummm.... you will need custom pistons with the correct valve reliefs. You can't just bolt the head an block together without any work.
Also, make sure the oil and water passages line up correctly!
-Charlie
Old 04-18-2005, 06:43 PM   #5 (permalink)
"I BUILD SLEEPERS"
Wraith's Avatar
View Wraith's Photo Gallery
lol... yeah you definitly need the 3s-gte pistons ...
MySpace:
http://www.myspace.com/335453
Wraith is offline   Reply With Quote
