What the hell!! Where is this leak coming from??? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-13-2005, 05:25 PM   #1 (permalink)
View PoR2GeEzCamry's Photo Gallery
2nd Generation What the hell!! Where is this leak coming from???
My 89 camry 3sfe has 218,000 miles, and about a month ago its been leaking oil at a good rate. Theres a nice little puddle under the left side of the engine after a couple hours. I just had it checked out and they said they put it on the lift for 2 hours to see where its coming from, but they said it didnt leak!! then they parked it and when i got there, a nice little pudle had formed under the car as usual. They were surprised. Where can this be coming from? It leaks out under the left part of the engine near the oil pan. Anyone know what is causing this? Hopefully you guys can help. thanks
PoR2GeEzCamry is offline   Reply With Quote
Old 04-13-2005, 05:41 PM   #2 (permalink)
N/A bites
Tercel GTS's Avatar
At 218k it may be a rear main.
雄のハヤブサ
Tercel GTS is offline   Reply With Quote
Old 04-13-2005, 07:38 PM   #3 (permalink)
yea i thought so at first, but im not sure. Anyone got any ideas of what it could be? It seems to leak around the tranny area, and the oil pan area! Also, when they had it on the lift, the car was supossedly running, would this affect the oil leak? Would it only leak if the car is off?
Old 04-13-2005, 08:17 PM   #4 (permalink)
N/A bites
Tercel GTS's Avatar
That's hard to say, watch for yourself and see if it leaks right after shutting off.
雄のハヤブサ
Old 04-13-2005, 08:35 PM   #5 (permalink)
View tightcamry129's Photo Gallery
Maybe the "o" ring?
tightcamry129 is offline   Reply With Quote
Old 04-13-2005, 08:42 PM   #6 (permalink)
View Loan Wolf Cam87's Photo Gallery
2nd Generation
Dude Im almost sure its the O-ring, I got a 87 cam and I have the same issue, maybe check the front tranny pump or it may be the upper seal of the oil pan
One Monkey Don't Stop No Shiw
Loan Wolf Cam87 is offline   Reply With Quote
Old 04-13-2005, 10:25 PM   #7 (permalink)
Where's my boomstick?
Tommy's Avatar
View Tommy's Photo Gallery
I had the same problem, here's where it was leaking:
Rear Mail Seal
Head Gasket
Oil Pan
Intake Manifold
Valve Cover
At that rate, i was loosing .5qt a week, but the valve seals were shot too, so figure maybe half that was being burned off. And the car only had 140k.
My garage
1991 Nissan Maxima SE V6 5SPD - daily beater - Sold
1988 VW GTI 1.8l 16v - weekend beater - Blown engine
2005 Elantra GT sedan 5spd - Woo, no more beatup cars!
Tommy is offline   Reply With Quote
Old 04-14-2005, 08:32 AM   #8 (permalink)
Rear Mail Seal
Head Gasket
Oil Pan
Intake Manifold
Valve Cover
if you dont mind me asking how much did that dent your pocket and what Gen was it??
Old 04-14-2005, 08:43 AM   #9 (permalink)
Sold out for a Max
TheMajesticking's Avatar
View TheMajesticking's Photo Gallery
My car has a oil leak too. I am too scared to see what the exact problem is so I just ignore it and add oil as needed. I think I will find out next week.
Good question.
-Chris
TheMajesticking is offline   Reply With Quote
Old 04-14-2005, 08:57 AM   #10 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Left side of the engine meaning the side by the belts? Just wanted to make sure, cos some noob on here was refering to his engine when sitting in the drivers seat.
Front main seal: Lower left side (the side with belts) of the engine.
Rear main seal: Right side of the engine. Area between the block and tranny.
Oil pan gasket
Cam seal
Oil pump
"Skoolin' the unlearned!"
Old 04-14-2005, 09:28 AM   #11 (permalink)
Noob witha Wrench
View boken's Photo Gallery
Lol ive got the same problem. I have no clue where the leak is coming from....i know when it started.I changed my oil and my washer fell off the nut when i was putting it back on to the oil pan, thats when the leak started and the next time I changed it i put the washer back on but to no avail....the leak still lives........... GRR
boken is offline   Reply With Quote
Old 04-14-2005, 10:37 AM   #12 (permalink)
Gameroom cash: $147537
See if you got oil in disturbutor cap.
Old 04-14-2005, 12:08 PM   #13 (permalink)
Tommy's Avatar
oh yea, forgot about the cam seal...lol
As for the price to fix all this? I said screw it and bought a new engine. lol
To get everything fixed, the guy said a rough estimate would be thousands. I bought a JDM 3SFE and replaced it for about $600 total once it was all said and done, but i did the work myself.
My garage
Old 04-14-2005, 01:27 PM   #14 (permalink)
yea this is the side with the belts lol. So 88le, it could be any one of those parts you suggested? How can u tell for sure? Is there anything i can check to verify where its coming from?
Pineapple, i will check the distributor cap to see if there oil in there. I think once a while ago this mechanic mentioned something about my distributor cap. If there is oil in there, what could be causing this? thanks guys
Old 04-14-2005, 05:15 PM   #15 (permalink)
alright guys, i did a test to see if the car leaked oil when the car was on and off. I left the car off for an hour with cardboard under it, and a good sized area leaked from the oil pan area as usual. I turned the car on with the cardboard under again, but the car did not leak any oil when it was turned on. I took some pictures of the areas its leaking from:
As you can see, the bottom of the oil pan is drenched in oil. But upon investigation, its also leaking from an area behind the oil pan too. Its a piece connected to the suspension:
I popped the hood to see if i could see any areas that looked wet from oil, and i found that the black plastic cover on the side of the engine near the belts had some oil on it too:
Also, on the intake manifold, on the pipes that connect to the#1 #2 cylinders, theres is oil that looks to have leaked on it. I thought i would post these pics and see what you guys thought about what needs to be fixed. thanks guys
