seafoam on 1mz - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-13-2005, 05:47 PM   #1 (permalink)
View 2olforthis's Photo Gallery
seafoam on 1mz
I'm looking to verify the location of the brake booster vacuum hose on my 1999 V6. Consulted the manuals but didn't find a definitive answer. Does this hose extend from the large, black round object (brake booster?) behind the brake master cylinder and snake along the fire wall before connecting to the right side of the throttle body? Also, I read in the manual that the engine may have to be above a certain rpm in order for there to be vacuum. If I am right and I disconnect the hose at the booster end, the seafoam will be added directly into the throttle body from the side. Sound correct? Any 1mz experience would be helpful.
2olforthis is offline   Reply With Quote
Old 04-13-2005, 06:45 PM   #2 (permalink)
camry> /RAPES\ <honda
Jagwire's Avatar
View Jagwire's Photo Gallery
all i know.. look for the hose that is near where you insert your brake Fluid at.. but get a verification i am ganna do the same Seafoam to mine so anything ya learn would be more than grateful..me ganna go pop the hood and look you got same Gen as me.. so.. we can help each other ^^ lol anyway brb
1998 Camry V6 5 speed
Red Tint,Viper Hood Ornaments
White
Camry 4 Life
Jagwire is offline   Reply With Quote
Old 04-13-2005, 09:08 PM   #3 (permalink)
Answered my question with a good search. Jag - do a search for brake booster and click on a thread titled Seafoam posted by Canadiancelica. Shows the vacuum hose on a 4cyl but is in the same location on our V6. Driver's side with part on the firewall and connection to the lower part of the throttle body. Good luck!
Old 04-13-2005, 11:28 PM   #4 (permalink)
Always Under Construction
View whocares04's Photo Gallery
did u guys do it already?
just be careful and read the directions and dont stick the vacuum hose into the seafoam can or it'll suck up the whole can instantly and could have a high possiblity of hydrolocking ur engine...
-Matt
When in doubt, use the search function (link)...no one is spoon fed...
whocares04 is offline   Reply With Quote
Old 04-14-2005, 05:45 AM   #5 (permalink)
Good tip. I read that pouring about 5oz into the hose slowly would be a better way to go and that's what I intend to do. Good looking out. thanks
Old 04-14-2005, 12:18 PM   #6 (permalink)
Jagwire's Avatar
if your car is a 97-01.. you find the (Dot3 fluid " brake fluid") and you see a pipe behind it.. its in the shape of an L pointing downwards.. looks like it just STOOPS.. but thta is it
White
Camry 4 Life
Old 04-14-2005, 01:13 PM   #7 (permalink)
Advanced Noob
brungold's Avatar
View brungold's Photo Gallery
if its the same as the 5S, here's that pic again of where it goes.
| 1995 Camry LE 5SFE [sold] | 2003 Highlander 1MZFE [sold] | 2006 Tacoma PreRunner 1GRFE [gone] | 2008.5 Audi A3 2.0T [now]
FS: Navone N-85V Line-Out Convertor for connecting amp/sub to Factory HU
brungold is offline   Reply With Quote
