Here's what you need to do...
1) Unbolt the bracket holding the two VSV on the engine. (2 10mm bolts)
Throw that away...
2) Look under the battery. You will see the vacuum tank that stores vacuum for the ACIS system. (follow the long vacuum hose to it) Take the vacuum tank out, and throw it away...
***KEEP BOTH VACUUM HOSES*** We are ging to re-use them.
3) On top of your throttlebody there are three vacuum ports. They are switched from low vacuum under 3,000rpm, to high vacuum over 3,000rpm.
The two facing the PASSANGER side of the vehicle are used for controlling the EGR system. This is the bane of the entire engine... Unplug BOTH control hoses. Keep them ONLY if you have emessions checks.
4) Reset the ECU... Pull the EFI fuse for 5 seconds = ECU Reset. (We need the ECU to quickly correct for a different air/fuel strategy)
5) Configure the vauum valves as follows. The FPR goes to the front most port. *a note* The FPR will now be recieving vacuum much earlier than before. The fuel system will be squirting much more fuel at low load levels. Enough to affect gas mileage.
The ACIS vacuum hose goes to either of the middle ones.
We've accomplished three important performance goals.
1) The ACIS valve will now slam shut very early. If you open the throttle at IDLE, there will be enough vacuum to shut it. This will improve performance under the (car moving), 3900rpm, and 50%+ TPS when it normally switches. (Flap open = good low end torque my ass... it looses power any time it's open)
2) The EGR system WILL effectively be blocked. At least for the most part. It will still leak exhaust so you'll definately want to block it off if you don't use emessions.
3) You now have the fuel pressure on the stock system to support a turbocharger without ugprades at LOW engine load/power levels. (no re-tuning required for cruising)
