Stoid Racing Built 1mz ALMOST DONE! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-15-2005, 09:15 PM   #1 (permalink)
Boost n' Juice Maniac
iTrader Score: 9 reviews
View trd4life's Photo Gallery
Stoid Racing is in the finishing stages of my built 1mz engine, i cant wait to put this beast in. Here is some of what my new setup consists of
Oversized Forged Arias Pistons 9:1 compression
Modified 22R Eagle Rods
Crank - balanced and magnafluxed
Modified combustion chambers in heads
Stoid Racing Custom Exhaust Cams
ARP main studs, head studs
Multi layer metal headgaskets
Lightweight 1zz lifters
HV oil pump
Perma Cool oil cooler
TRD 160 thermostat /TRD radiator cap
Ported heads, intake manifold, TRDsupercharger(2.1" pulley)
DEI CO2 air intake, fuel bar,and custom Stoid intercooler plumbed through the lower intake manifold
ATS knock sensor upgrade
75mm mustang throttle body with custom adapter plate for TPS and IAC
Injen intake with UPFD extension
XERD long tube headers with 02 simulator/ported exhaust ports on heads,3" catless exhaust, 3" flat black Vibrant muffler
400cc injectors with SAFC , Jim's fuel kit and fuel reg. mod,URD 190lph pump
Apexi Rev/Speed meter with Speed limiter cut
Split Second ESC-1 Signal Conditioner
EGR block off plates with resistors to prevent CEL
Coolant bypass mod
Magnecore KV85 wires, NGK iridium plugs, IS Plasma booster, MSD DIS-4
SPEC stage 4 clutch, Fidanza flywheel, Phantom Grip LSD
Speed Source shifter Cable bushings,Shifter base busings, Extended Slave cylinder pushrod
TRD short shifter
DIY Poly rear engine mount, Jim's torque Rod, Superpro Dogbone bushings
i am gonna see how much power i can make with this 14psi setup. If its not over 330whp i am gonna throw a 100 shot at it.
Special thanks to my father.Brian from Stoid Racing,Bob Garner from TRD,RJ@UPFD, gLok,Tony the Tiger,Doug Lila, and JoeB for your continuing help on this project.
Questions/comments appreciated
more updates coming soon....
2000 Camry LE v65 speed
Supercharged at 7psi 13.5 at 107.3mph
Dynoed 273.8whp 282tq. on stock internals
1999 Solara v6 auto 13.0 @113mph s/c'd 9.5psi and nitrous
2000 Camry v6 5 speed 13.5 at 107.3mph s/c'd at 7psi
1997 Camry i4 auto to v6 auto swap! Built 3.3 3mz/1mz hybrid
trd4life is offline   Reply With Quote
Old 04-15-2005, 09:23 PM   #2 (permalink)
Local Rape Machine
View ekim55121's Photo Gallery
i just creamed my self
ekim55121 is offline   Reply With Quote
Old 04-16-2005, 03:36 AM   #3 (permalink)
Fooly Sik RE!!!
View Wibbit's Photo Gallery
damn! cant wait to see this thing go!!! keep us updated
1996 5 speed Vienta V6 Touring
|Rays Engineering|TRD|Unichip|BMC|Magnaflow|Whiteline|BR IDE|Endless|
My Vienta Website
Wibbit is offline   Reply With Quote
Old 04-16-2005, 12:06 PM   #4 (permalink)
poor college student
userlain's Avatar
View userlain's Photo Gallery
'91 Camry @ ~162,900 miles
userlain is offline   Reply With Quote
Old 04-16-2005, 04:14 PM   #5 (permalink)
Breakin' necks since '02!
Durrby's Avatar
iTrader Score: 12 reviews
View Durrby's Photo Gallery
Originally Posted by UfoZ
this thread is worthless without pics.
Bagged 1995 Toyota Camry LE I4 92k
1999 Lexus SC400 153k
Durrby is offline   Reply With Quote
Old 04-16-2005, 04:26 PM   #6 (permalink)
RedKnight
View JoeB's Photo Gallery
Great job Gabe! I can't wait to see that monster in action. Gabe's is one of them that I was talking about that will be faster than mine! -JoeB
Please stop by and rate my ride:
http://www.cardomain.com/id/jbailer
JoeB is offline   Reply With Quote
Old 04-17-2005, 01:32 AM   #7 (permalink)
camry> /RAPES\ <honda
Jagwire's Avatar
View Jagwire's Photo Gallery
i wanna see too
1998 Camry V6 5 speed
Red Tint,Viper Hood Ornaments
White
Camry 4 Life
Jagwire is offline   Reply With Quote
Old 04-17-2005, 01:44 AM   #8 (permalink)
View mkII's Photo Gallery
whoo... sounds like a monster.
i miss my mkii.
Gen 5 - 2002 Phantom Gray Pearl Camry V6 LE:
-TRD Rear Sway Bar
-SE Model Strut Tower Bar
-Borla Exhaust
-Injen Intake
-Sportivo Grille
-TRD Lowering Springs (sitting in my room waiting to be installed)
mkII is offline   Reply With Quote
Old 04-17-2005, 11:32 AM   #9 (permalink)
View warlock's Photo Gallery
Originally Posted by Durrby
werd
94 Scepter 1MZ-FE
< TN Type [R]ice Club>RICERS UNITE!! Join Type R..latest faction of TN!!
.....http://www.toyotanation.com/forum/sh...d.php?t=105457
warlock is offline   Reply With Quote
Old 04-17-2005, 12:44 PM   #10 (permalink)
rusty9's Avatar
Gameroom cash: $442005
View rusty9's Photo Gallery
mind if the curious ask how much $$$?
rusty9 is offline   Reply With Quote
Old 04-17-2005, 01:30 PM   #11 (permalink)
about 8k so far in the motor alone
Old 04-17-2005, 04:59 PM   #12 (permalink)
Rocket Surgeon
woody's Avatar
View woody's Photo Gallery
The 22r rods, what had to be modified to make them work? Crank diameter or wrist pin?...
woody is offline   Reply With Quote
Old 04-17-2005, 05:45 PM   #13 (permalink)
RedKnight
Nah, the crank diameter and wrist pins were fine, the rod it just SO fat and there isn't much room. Pin height on the Arias pistons has to match up right too because the Eagle 22R rod is longer than the stock rods on the 1MZ-FE. Look on my CarDomain page and you can see the difference between the Eagle rods and the stock rods. As you know, the 22R is a 4 cylinder so at Stoid Racing they come up with a matched set of 6 rods and custom machine them to fit. They do a lot of very cool high performance work. That's where I got my pistons and rods from. I got the idea from Brad Bedell who had his 1MZ-FE built for his MR2 there. -JoeB
Old 02-19-2008, 05:44 AM   #14 (permalink)
View BIGBOOSTCAMRY's Photo Gallery
Hey there!, I am a newby to this site but i am interested in your 1mz that you are or have already got on the road. I am doin pretty much the same as yourself but i am turbo'n it i just want/need to know what head studs you used, ie what was their original application? cheers!!!
BIGBOOSTCAMRY is offline   Reply With Quote
Old 02-19-2008, 05:52 AM   #15 (permalink)
deviate from the absolute
Knailgun's Avatar
Gameroom cash: $285780
iTrader Score: 40 reviews
View Knailgun's Photo Gallery
holy 2 year old thread revival.....
version 4.0 is here http://www.toyotanation.com/forum/sh...56#post3188156
Knailgun is offline   Reply With Quote
